zoom zoom BOOM - Carnage pics added!
marcdh
Post by marcdh »
Hey guys,
Was out for lunch, hit maybe 6500 in 1st gear, then bam! sounded like a tractor.
At first I thought my timing belt has slipped a few teeth. So I tried adjusting my adjustable cam pulley, and managed to get it to idle, though noticed the rear cam was very stiff. It still sounds like a tractor. The rear cam sprocket is bouncing up and down. I think something may well be destroyed in the rear head :( I've had a ticking for a while, assumed it was stuck HLA, maybe somethings really gone.
Any guesses? I'm going to get my Dad to tow it home tonight after work.
Pretty gutted,
Marc
EDIT VIDEO ADDED:
Youtube Video
It's hard to see, but the rear cam is bouncing around as if it's not tightened, but it really is.
View Worklog
Re: zoom zoom BOOM? - help please :(
Post by wytbishop »
sounds pretty clearly like a broken camshaft. Didn't you have a camshaft that was damaged in transit and repaired? Could it be that same shaft?
marcdh
Post by marcdh »
Ironically that one was actually the front bank intake cam with broken balancing lobe, the front intake cam had the scores that were metal welded. So the back ones were actually in the best condition! Sounds like these cams were set to fail. This is my second set of cams too :( The kl01 sprocket pin bent, now this!
View Worklog
hgallegos915
Post by hgallegos915 »
Hey man dont give up and keep at it :D
-hec
JM1EC-V6
Post by JM1EC-V6 »
Sounds like a dropped valve. Take the engine's compression pressure.
'94 Mx-3 GS-R SE, KL-ZE Interprep. (From '96 PGT KL)
1110Kg
-Interprep KL31 Spec.
ported heads, Polished combustion chamber,3 angle vlv job,10.3:1 C.R.,0.020'' O.S.,KL31 cam,-0.007'' heads,Long neck IM,KL31 TB, Hotshot headers,2.25'' exhaust,Magnaflow cat
Post by wytbishop »
A dropped valve would not account for the wobbly cam gear. Unless breaking the valve caused the camshaft to snap. Won't know until the lid is off.
Ryan
Post by Ryan »
In an entirely insensitive manner, I'm quite excited to see what happened.
projectzemx3
Post by projectzemx3 »
Ryan wrote:In an entirely insensitive manner, I'm quite excited to see what happened.
ya me too.
its not really misfiring tho, you would think with a broken camshaft it would miss fire.
NEED PARTS INSTALLED? PM ME!
Ryan
Post by Ryan »
Well think about it.
It must have broken between the end journal and the 1st journal, or the pully wouldn't wobble. So two pistons have valves stuck at a position, any position. I'm just breakin into the v6's... the pully is coaxial with the intake cam on the rear bank? So a pistion could easily be firing out of the intake, making all that racket. Nevermind the broken cam grinding against itself, and all that metal crap that is being washed around the motor, and the misbalance, and the cam gears (inside the head) seeing damage from the one wobbling, and the engine not seeing the regular balance from the power stroke, because there is no compression in at least one of the 3 rear cyls...
Or maybe the cam broke elsewhere, just after the internal gear?
I'm just excited.
TAKE LOTS OF PICTURES!
_-Night-Shade-_
Post by _-Night-Shade-_ »
Ryan I think you're turning it into a bigger thing than it really is :lol:
How'd you start the car without pushing the clutch?
RX8SE3P
Post by RX8SE3P »
Damn sorry to hear mate.
Let us know what you find. Fingers crossed you can get away with not replacing the engine!
1995 Eunos 30x KLZE
marcdh
Post by marcdh »
hgallegos915 wrote:Hey man dont give up and keep at it :D
Thanks Hector, I will one way or another!
JM1EC-V6 wrote:Sounds like a dropped valve. Take the engine's compression pressure.
To be honest I'll probably take the valve cover off first, just turning it over makes me cringe. I'd be surprised if the interprep setup let a valve go after just 10k miles at that RPM.
haha yes so am I.
projectzemx3 wrote: its not really misfiring tho, you would think with a broken camshaft it would miss fire.
It was missfiring horrifically, it's hard to hear amongst the other racket.
RX8SE3P wrote:Damn sorry to hear mate.
Thanks. I don't care much about the bottom end, its the kl31 1a1 heads I invested time in: kl31 cams, port and polish exhaust ports, knife edge intake ports, removing cast marks, lapping valves, interprep springs etc... But pretty damn sure the heads are the problem!
_-Night-Shade-_ wrote:Ryan I think you're turning it into a bigger thing than it really is :lol:
Clutch is fine, not sure what you mean?
Teardown shall begin today after work, lot's of pics to follow, if there's carnage worth photographing!
View Worklog
marcdh
Post by marcdh »
Today I got stuck into the teardown...
Got the intake manifold off and saw this:
Oil lying on top of the valves.. only on the rear head. So I was think hmmm, blown head gasket?
Then I took off the cover, and noticed an alignment issue:
Next I noticed a bloody big cracked in half camshaft!
I think it's also no coincidence that the cam cap at the crack point felt quite loose. So looks like in my 3rd cam overhaul I may have messed up big time. Either that or the bolts worked loose, I'm so meticulous, yet I remember rushing that job to get to work etc the next day :( Mind you it's been ticky but fine for 5000+miles!
So that is the exact cam that the sprocket pin failed on with my kl01s, so I'm all outta cams! Damage to the head and caps seems minimal and negligable. I'm a bit concerned why all that oil was lying on the valves, why would that oil be sitting up there?
View Worklog
fowljesse
Post by fowljesse »
:crying: I'm sorry to read about that. Your car is one of my all-time favorites.
I have a set of KL31s with one damaged in transport that I can sell you cheap. Hopefully the damaged one isn't the one you need. I can send you a couple pics if you're interested.
marcdh
Post by marcdh »
Ahh thanks man that would be fantastic! I've got to make sure the rest of the engine is salvageable first before I commit though. But If you could check if you have the rear intake cam in one piece that'd be lovely.
I'm worried most about why all that oil is sitting there on top of the valves :?
View Worklog
