hgallegos915 wrote:Hey man dont give up and keep at it
Thanks Hector, I will one way or another!
JM1EC-V6 wrote:Sounds like a dropped valve. Take the engine's compression pressure.
To be honest I'll probably take the valve cover off first, just turning it over makes me cringe. I'd be surprised if the interprep setup let a valve go after just 10k miles at that RPM.
Ryan wrote:In an entirely insensitive manner, I'm quite excited to see what happened.
haha yes so am I.
projectzemx3 wrote:
its not really misfiring tho, you would think with a broken camshaft it would miss fire.
It was missfiring horrifically, it's hard to hear amongst the other racket.
RX8SE3P wrote:Damn sorry to hear mate.
Let us know what you find. Fingers crossed you can get away with not replacing the engine!
Thanks. I don't care much about the bottom end, its the kl31 1a1 heads I invested time in: kl31 cams, port and polish exhaust ports, knife edge intake ports, removing cast marks, lapping valves, interprep springs etc... But pretty damn sure the heads are the problem!
_-Night-Shade-_ wrote:Ryan I think you're turning it into a bigger thing than it really is
How'd you start the car without pushing the clutch?
Clutch is fine, not sure what you mean?
Teardown shall begin today after work, lot's of pics to follow, if there's carnage worth photographing!
