Oh dude you shouldn't ever be in neutral unless you're stopped. When you're coasting in gear above something like 1200 RPM the fuel injectors are completely off. Sure in neutral it doesn't slow down as fast but it actually takes fuel to idle, which is essentially what the car is doing when you're coasting in neutral. But yeah other than that I'm not too sure what the issue with yours is, especially since like you said it seems you've checked everything.mikeinaus wrote:also keep in mine when i say im getting close too 11l/100km now thats with throwing the car in neutral and coasting whenever possible and some hypermilling techniques
V6 fuel mileage
- _-Night-Shade-_
Re: V6 fuel mileage
Re: V6 fuel mileage
i meant cruising on level ground. i engine brake on hills whenever possible. idle at 60km/h uses about 2l/100km while holding a steady rpm in gear at the same speed on flat/level ground uses about 6-7l/100km_-Night-Shade-_ wrote:Oh dude you shouldn't ever be in neutral unless you're stopped. When you're coasting in gear above something like 1200 RPM the fuel injectors are completely off. Sure in neutral it doesn't slow down as fast but it actually takes fuel to idle, which is essentially what the car is doing when you're coasting in neutral. But yeah other than that I'm not too sure what the issue with yours is, especially since like you said it seems you've checked everything.mikeinaus wrote:also keep in mine when i say im getting close too 11l/100km now thats with throwing the car in neutral and coasting whenever possible and some hypermilling techniques
Re: V6 fuel mileage
stock k8 i got about 25mpg ... CAI, cat off, Denso, 17" rims 225 tires i get about 20mpg... not good at all
K8 :: 136.8 bhp---160 nm---108.0 whp---118lbs/torque
ET: 15.567 @ 136 kmh (84 mph)
"Racing a Honda is like being in the special Olympics, you may win, but in the end your still retarded."
- MrMazda92
Re: V6 fuel mileage
City, or highway? You're a patient driver, either way. Most people like to leave for work 10 minutes late and "make it up" on the road. I leave 10 minutes early, and calculate the most efficient route(time, as well as fuel consumption) by taking alternate routes until I find a few good ones.mitmaks wrote:~30mpg is what I get with my K8 also.
- _-Night-Shade-_
Re: V6 fuel mileage
Lol you're tellin' me.OutlaW wrote:225 tires i get about 20mpg... not good at all
- mitmaks
Re: V6 fuel mileage
That's highway, city I get 23.5-24MrMazda92 wrote:City, or highway? You're a patient driver, either way. Most people like to leave for work 10 minutes late and "make it up" on the road. I leave 10 minutes early, and calculate the most efficient route(time, as well as fuel consumption) by taking alternate routes until I find a few good ones.mitmaks wrote:~30mpg is what I get with my K8 also.
Re: V6 fuel mileage
Anyone know how much of an impact on economy an improperly adjusted tps could have with no noticeable effect on performance? My current tanks mileage was averaging close to 12l/100k. I unplugged it for shits and giggles and my.average has dropped to 11.5l/100k with more or less the same driving on the same tank. I also noticed no difference in performance other then a slightly higher idle with it unplugged...
I'm gonna swap it with a spare and properly adjust it next week. I'm just curious how much the reading is referenced for a/f mixture
- MrMazda92
Re: V6 fuel mileage
It'd be nice to top 29 highway... I've been driving a Civic hatch to Salem every few days for weeks now, and It's killing me slowly... At 40+ mpg, I can't even try to justify driving the MX-3 there, but It's tempting anyways.
- _-Night-Shade-_
Re: V6 fuel mileage
Very important.mikeinaus wrote:Anyone know how much of an impact on economy an improperly adjusted tps could have with no noticeable effect on performance? My current tanks mileage was averaging close to 12l/100k. I unplugged it for shits and giggles and my.average has dropped to 11.5l/100k with more or less the same driving on the same tank. I also noticed no difference in performance other then a slightly higher idle with it unplugged...
- BornSticky
Re: V6 fuel mileage
i drive my gf's old del sol 1.5 to work cause it gets me 42 mpg and it kills me to be seen in it..... but i probably save about 200 bucks a month..MrMazda92 wrote:It'd be nice to top 29 highway... I've been driving a Civic hatch to Salem every few days for weeks now, and It's killing me slowly... At 40+ mpg, I can't even try to justify driving the MX-3 there, but It's tempting anyways.
#5389 to join MX-3.com
- MrMazda92
Re: V6 fuel mileage
Exactly, it's a trade-off
Re: V6 fuel mileage
8.8L / 100 km city or ~32 MPG in my K8
completely stock 12 degrees ignition advance with NGK platinum plugs
1994 MX-3 RS
B6 goodies for sale:
viewtopic.php?f=2&t=66333
- _-Night-Shade-_
Re: V6 fuel mileage
8.8L/100km is 26.7mpg...Mi|<E wrote:8.8L / 100 km city or ~32 MPG in my K8
Re: V6 fuel mileage
I did the conversion in about 2 seconds in my head
Its 26.84 MPG now that I use a number machine
Best ive had is on the highway was 6.9 ish L/100k which was
34.09 MPG from Kamloops to Golden.
1994 MX-3 RS
Re: V6 fuel mileage
I get between 8.8 and 9L/100km in mixed city driving (lots of freeway time mixed with stop and go) on my ZE. If I drive a long highway trip I have seen the high 6's, but I hardly ever do a full tank of all highway driving so it's hard to say what my hwy consumption is with any accuracy.
