![Freak :freak:](./images/smilies/freak.gif)
That special tool is a pulley puller. The 2 bolt holes are for it and not for cranking the bolt loose.mikeinaus wrote:it has 2 other small holes that are meant for a special tool to hold while you crack the bolt loose
haha, i watched that video a lot when i had to do my timing belt for the first timeSuperK wrote:It just clicked. You can make a doohickey to remove the crank bolt out of a piece of metal. Months ago I was listening to the "King of Miatas" and he did show how he removed his while the engine was out. It's around minute six so you can skip through a lot of it. No it's not a K series but the tool is the same concept.
http://www.youtube.com/watch?v=oovptq0q ... re=related
i just went threw the online manual and according to it there is a special tool that is meant to connect to the flyweel and stop the crank from moving on that side. that being said we have alldatapro at school and it showed a special tool that physically held the crank in place using the 2 holes meant for the puller on the harmonic balancer._-Night-Shade-_ wrote:That special tool is a pulley puller. The 2 bolt holes are for it and not for cranking the bolt loose.mikeinaus wrote:it has 2 other small holes that are meant for a special tool to hold while you crack the bolt loose
Are you serious? Wow I'm surprised, they're really small holes. But yeah I've always been able to take mine off with an impact.mikeinaus wrote:i just went threw the online manual and according to it there is a special tool that is meant to connect to the flyweel and stop the crank from moving on that side. that being said we have alldatapro at school and it showed a special tool that physically held the crank in place using the 2 holes meant for the puller on the harmonic balancer._-Night-Shade-_ wrote:That special tool is a pulley puller. The 2 bolt holes are for it and not for cranking the bolt loose.mikeinaus wrote:it has 2 other small holes that are meant for a special tool to hold while you crack the bolt loose
i doubt making a tool would be that difficult, i just dont have many tools at home so i doubt its possible with what i have on hand. i think im just going to have to leave my car in the shop longer then i wanted too. ill get everything i can done before the cover arrives so i can hopefully finish it in a day or 2 when it finally does..
