So I double checked all the cables. I had the disty ignition wire wired up to the ecu AND megasquirt at the same time. I hope I didnt fry anything. I clipped it as per instructions and connect to megasquirt in the right wire. Double verified all the wires and NO spark .
I have voltage to the HEI and I have voltage reading in the distributor ignition wire. I have fuel. Megatune reads spark on/ fuel pump on. I checked fuses on driver side and they are good. Checked fuses and relays on engine bay and its all good. I dont know what else I am missing. It would start right up before the wiring. Megasquirt has a red light and I can ee values move around in megatune. I can also see rpm while cranking. I can tps, temperature a/f .
Any tips will be greatly appreciated.
Im wired! But ni spark :(
-hec
- marcdh
Re: Im wired! But ni spark :(
Did you try having MS run fuel only?
I'd recommend running MS with inputs only first, to make sure you're getting the RPM, CLT, IAT etc before committing. Though that doesn't help you much.
Upload your msq and datalogs of attempted starts.
So are you actually getting signal to spark from MS to the disty?
View Worklog
View Worklog
New development... when I connect the injectors I get no spark.. and yes spark when they are not connected. So I removed megasquirt and connect the ecu.. no spark.. then I changed ecu, changed coil, and got spark but no start. My goal for now is to start the car without megasquirt. I dont understand what would cause spark to not be present.
Also the instructions clearly say that I need to cut the wire for the disty signal and put it into megasquirt but I get no spark unless its connected to ecu. ugh.. next weekend ill do more testing I know the car is way beyond flooded so ill wait a few days. There was fuel coming out of the turbo flange..
-hec
- WhiteFinish
Does it run with standard ECU?
Than biep with a multimeter all the wiring. Check if you have solid connections to the Megasquirt unit.
Remember to cut the right wires (injectors and distributor ignition output.)
- marcdh
Any luck Hector?
I'd consider trying megasquirt again if you're going no where with the standard setup. MS is easier to troubleshoot IMO.
My list would be this:
-reinstall MS
-triple check wiring
-disconnect injectors or fuel pump
-ensure you have RPM signal, take a log, make sure it's a sensible figure IIRC 200rpm or so, check PT
if you have RPM and still no spark:
check 12volt on the thick wire at the disty, blue is it?
check the signal is coming out of ms
-reinstall MS
View Worklog
View Worklog
