I have voltage to the HEI and I have voltage reading in the distributor ignition wire. I have fuel. Megatune reads spark on/ fuel pump on. I checked fuses on driver side and they are good. Checked fuses and relays on engine bay and its all good. I dont know what else I am missing. It would start right up before the wiring. Megasquirt has a red light and I can ee values move around in megatune. I can also see rpm while cranking. I can tps, temperature a/f .
Any tips will be greatly appreciated.
