[GI] ITB's for all 4 cyl models
Re: [GI] ITB's for all 4 cyl models
ok i will sugest this for those of you who are not techno savy
for the price of a ms1 board plus say 20$ for materials to solder i could assemble your kit and send it all as one so all you would have to do is splice into the original ecu(instructions included)
if everyone is interested i could contact diyautotune and see about bulk buy discounts
as far as hassle gos all you have to do is remove a panel to see the ecu, splice the needed wires with splice connectors, and clip the 3? wires from the mass air flow sensor and run them to the map sensor which could be included.
feedback??????
still waiting to hear from jw motor sports...
feedback??????
1994 MX-3 1.6L B6DE 16v DOHC - rear disc swap, nix power steering/ac, Corksport f&r strut tower bars, Pedders urethane control arm bushings, urethane motor mounts, steel braided brake lines, painted dash, protege tranny
90 Miata w/ b6, Konig Lightspeed rims, Cams (boost to come soon)
74 Porsche 914 w/ 1.8L - restoration prooject
I like the sound of that myself...
- fowljesse
Yeah, they'd ned to be truly independant from eachother. I've tried to talk to Leo. He's like Yoda (Vaughn); too busy working on stuff to be online.4gotn wrote:i could make them for the k8 and klze but i would have to have a motor.
plus the design would have to be a little extravagant and may not have room due to the mx3s limited under hood space...
could just do like the old days though and have velocity stacks through the hood....
its feasible....
I wouldn't mind having to have a hood scoop
when jw FINALLY responds to me ill see if maybe he doesn't have a k8/klze manifold or at least a gasket to go byfowljesse wrote: Yeah, they'd need to be truly independent from each other. I've tried to talk to Leo. He's like Yoda (Vaughn); too busy working on stuff to be online.
the main issue you'll be facing is the flow of air. your intake will be almost smothered being as its directly under the hood hince the scoop
ill see what i can do about the throttle bodies to give you a definate
what about just a three pack?
Can't wait! I've been looking into doing that too for mine, and I was looking at itb setups for miata's. they were going for 2,500. Hopefully yours will be a bit more feasible.
95' Mazda Mx-3
1986 bmw 325e-rust in peace
1996 Subaru Outback-Sold
2002 Bmw 325XIT
2002 Bmw 325XIT
I really like this. I am not a mechanically inclined fellow. If you could do a basically complete bolton part with an MS piggyback or somethin I would be really down for this. I love custom mx3 parts!
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
everyone who is defiantly interested or possibly interested just pm me so i can keep track of it
itll help with bulk buys if i can pitch a number at them
just need a pm saying defiantly or possibly
- Ryan
I'm interested too... but maybe in a few years. Ha.
an idea for you v6 guys
let me know what you think
Well I contacted diyautotune and as of this moment the product will be about $160 for the v2.2 ms1, db9 to usb conversion w/ cable (for tuning), and necessary wiring for me to make the pigtail. The haven't replied yet as to a discount but Im sure if i can get at least ten of you to commit i could get a good chunk knocked off.
still no word from jw....im thinking he may have fell off the side of the earth...
hes the only thing im waiting on for a final price
I do have a question, what the estimated horsepower gain with this and would you need a header like the one that corksport is bringing out.
95' Mazda Mx-3
2002 Bmw 325XIT
2002 Bmw 325XIT
- mx-3_4evr
To give you a rough estimate, I made 124WHP on a stock BP with header back 2.25", but low compression numbers (highest 125psi lowest 100psi, they are supposed to be at 180psi) Stock BP puts out 109WHP
thanx mx43vur
roughly a 50 hp gain over stock
headers are not needed but will help
all natural aspiration mods are relative, meaning installing a header will give you x horsepower and installing a camshaft will give you y horsepower but installing both will give you x + y = xy + z% gain
assuming you've taken algebra.....
- umcamara
You really weren't trying there!4gotn wrote:thanx mx43vur
- mx-3_4evr
Mx43vur??? that's it no more info for you!
jk
jk
