Problems after KLZE swap
Re: Problems after KLZE swap
Edit Delete
Edit Delete
Update:
I've purchase KL36 ECU and install it.
I allready had the JE50 VAF.
It's not the same car, now it "breathing" much better at all RPM range, but especially in the very high RPM.
Yestarday I want to diagnostics and found 3 error codes:
1. Both O2 sensor arn't good (it's the K8 sensors) - what kind of sensors I need to purchese for my ZE?
2. TP sensor is shorting, can't understand why, but I have another TP sensor from the K8 throttle.
3. Both Knoking sensors - that's wired 'cause I haven't done nothing that might hurt them, is it 'cause the TP sensor is shorting?
As far as I know I don't have "Chack Engine" indicator on my dash.
Is igniting daleying even available on my MX3?
