My thoughts exactly.
-7
1.8 heads on a 2.5 block
- se7en
Re: 1.8 heads on a 2.5 block
1992 mx-3 GS-T, 10-12psi, T3/t4 hybrid, Turbosmart WG, AFPR, SSAC TURBO pipes, MSD Blaster coil, K&N, AEM W/B, MSnS(full standalone), 225Whp street tuned(10psi), 245Whp (12psi)(300bhp!!!)
1992 Fairlady Z(JDM RHD) 2+2 TT black(done!)700whp+
Don't Click Here! Trust me,Time waster!
- nycstreetsoldier
well i just have the parts around to try it so i think im going to, see what im thinking is if i use the lower end from the kl03 the one with lower comp than the klze,then the head rasing the comp will only put me close to the klze block...dont know yet if ill be right but well see...
- se7en
interesting....if you want to spend the time, I say go for it
7
7
- fowljesse
Yeah, like i mentioned, you may learn something totally different that could not have been foreseen. I'm intrigued.
- nycstreetsoldier
anyone know the valve size's on both the 1.8 and the 2.5 ,and the valve seat sizes for both?
