Hmm, well you can use that for a few things. I know a few ppl that are using that for a PVC valve connection. I use that nipple for my cruise control on my car..
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
