kl and 5spd swap into a auto I4 car?
white94pgt
i have a 94 pgt right now and i want to put my turbo kl into a mx3. i think i found a good donor cra, but its a I4 with a auto trans. can i use the clutch assibily and shifter and all of that good stuff from my probe in the mx3? and can i use the probe axles? beside that i know i have to get mx3 v6 motor mounts, but are the I4 and V6 crossmembers the same? wiring isnt going to be a problem, i will just use the megasquirt and probe wiring harness.
thanks in advance for any help. a turbo kl in a mx3 is really going to be fun to drive!
1994 probe GT
white94pgt
- monty73741
my suggestion is a bp in a sohc is easier...the I4sohc to KL is everything fromt the firewall back has to be changed even the harness.
It can be done
It can be done
Jason Danaher
Please Help Support MX-3.com
Mazdaracer
white94pgt
Mazdaracer
white94pgt
- Limegreen mx-3
yeap done it myself too easier than it seems if ur good with cars.
white94pgt
