ok should i go with a drilled/sloted type from exedy for 200 or fork over an extra hundred for a six puck act stage 2 ????
im not looking for much just something more then stock but i dont wana waste money on a clutch thats crap
clutch choices
clutch choices
1994 MX-3 1.6L B6DE 16v DOHC - rear disc swap, nix power steering/ac, Corksport f&r strut tower bars, Pedders urethane control arm bushings, urethane motor mounts, steel braided brake lines, painted dash, protege tranny
90 Miata w/ b6, Konig Lightspeed rims, Cams (boost to come soon)
74 Porsche 914 w/ 1.8L - restoration prooject
![Image](http://img.photobucket.com/albums/v454/glytcher/mx3%20stuff/ZOOMZOOM-1-1.jpg)
Get a centerforce dual friction then. From my personal experice it held up to absolute hell (6krpm+ launches, lots of them) and is 100% streetable. If your going into puck clutches you are going to be in for a hell of a suprise and a lot of chatter.
While your doing this though you might want to look into dropping in a alluminum flywheel as well, since if the clutch install is done properly it will add no real work to the job.
-torp.
I don't own a Mazda.
thanks for the help
