can you use k8 EGR system for KLZE with no EGR
I'm planning to go ZE now and I was wondering if you could use the stock k8 exhaust manifold with the EGR on the ZE if it is blocked off. Can I just run without it too?
MX3 KL-DE, probe/mx6 ebay turbo pipes, T3/T4 50 trim @ 8psi, millenia injectors, SAFC2, intercooled,Greddy RS BOV, turbonetic 38mm external wastegate. Wisco 9.5 forged piston, millenia S rods, and high performance rings coiming in soon. Shooting for 400whp this summer.
Re: can you use k8 EGR system for KLZE with no EGR
it all seem pretty much interchangeable - I run a KLZE with the K8 EGR tubes & exhaust manifolds - no problem with emissions testing or with any fault codes.
yes
See this thread:
http://www.mx-3.com/ubb/ultimatebb.php?ubb=get_topic;f=15;t=004854
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
I'm getting a curved neck ZE. I was told that the egr port was blocked off does that mean that it doesn't have egr or is it just blocked off. If everything fits than I'll use my stock k8 exhaust manifolds.
