Front Bearing
- mrspanky79
Front Bearing
Ok this is my problem in the spring my cv boots where cracked (both sides)so a replaced them. In doing so the left(passenger) hub nut gave me a hard time to come off, wrecking the bearing in the process so i put a new one in. Since then I have replaced the same one in the summer and know it has just gone again. Do's any one have any idea why the bearing keeps going?
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
99 vitara 4x4
Re: Front Bearing
i was talking to a mechanic the other day, right before replacing the whole spindle assembly, and he said if you don't tighten it hard enough, it will mess up the bearing, try using a torque wrench, if you didn't do it before
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
- mrspanky79
Re: Front Bearing
That make some sense i never used a torque wrench. Right know im trying to fined a spindle at the junkyard if not i will try that. Do's any one else have any idea on what else would couse this.
99 vitara 4x4
99 vitara 4x4
Re: Front Bearing
Mr spanky, I believe the last person is corect when saying you should have used a torch wrench. <BR> But what I wanted to tell you is that you can save over 50% on front wheel bearings buy perchasing them for a 92-94 Ford escort. <BR> When I replaced mine Mazda gave me a price of $80each and I picked up the escort bearings for $30. <BR> Just an Idea.
- mrspanky79
Re: Front Bearing
Canadian Tire some were around $40 that also might be the problem. And when i put the nut on i tighten it as tight as i can and till the old marks (bent in part).
99 vitara 4x4
99 vitara 4x4
Re: Front Bearing
I worked at a Crappy Tire garage and had my wheel bearings done there by someone I could see that was decent, you can take it in for a free quote and do the work yourself if you wanted, they'll do alot to get your business.
- mrspanky79
Re: Front Bearing
i did the work my self but i bought both bearings from Canadian tire. I just would like to know why they keep going? I cant see how the torgue of the wheel nut will do it because there is a pin in there that holds the bearing in. If any one has any other ideas why or could explain it to me, thanks.
99 vitara 4x4
99 vitara 4x4
Re: Front Bearing
Mr Spanky, i am a mechanic, the only thing that sounds like is u have to much play to with the new barring(not having it tight to begin with)when u put a new wheele barring in that axil nut has to be very tight because any play u have in it will reduce the life of the barring. i would deffinatly look in a service manule for the torque spec. and use a torque wrench as sugusted befor.
- mrspanky79
Re: Front Bearing
thanks for the help im starting to see what you are saying im going to give it another try if I cant fined a different spindal this week. You are a mechanic how do you get the bearing out and it with out taking the spindal off of the car? I have been taking the spindal out and doing it on a bench press thats why i think we might of bent the spindal a little.
99 vitara 4x4
99 vitara 4x4
Re: Front Bearing
sorry i didnt get back sooner, that should be a press in barring (much like the ford escort) Snap-On makes a tool to do thoes type of barrings on the car, but it is vary expensive and not necessary unless u do them regularly. in your cace the best way to do it is to take the hub a--. off and use a hydrolis bench press. when u do make very shure to have the barring straghtbecause u can get the barring in the hub croked which can also kiss thoes barrings in a short amount of time. also make shure that the barring is seated all the way in the hub. i dont think that ive seen anyone bend a hub but anything is possible. most of the problems i see are with barring eg. not in all the way , in croked , axil nut loose, <BR>if u have any moor questions let me know glade to help.
- mrspanky79
Re: Front Bearing
Thanks for the help I think i know what the problem is know. By what you are saying I think we might of had the bearing slightly croked. Its very hard to do on a bench press.
99 vitara 4x4
99 vitara 4x4
