![Mad :mad:](./images/smilies/icon_mad.gif)
Front Bearing
- mrspanky79
Front Bearing
Ok this is my problem in the spring my cv boots where cracked (both sides)so a replaced them. In doing so the left(passenger) hub nut gave me a hard time to come off, wrecking the bearing in the process so i put a new one in. Since then I have replaced the same one in the summer and know it has just gone again. Do's any one have any idea why the bearing keeps going? ![Mad :mad:](./images/smilies/icon_mad.gif)
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
99 vitara 4x4
Re: Front Bearing
i was talking to a mechanic the other day, right before replacing the whole spindle assembly, and he said if you don't tighten it hard enough, it will mess up the bearing, try using a torque wrench, if you didn't do it before
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
- mrspanky79
Re: Front Bearing
That make some sense i never used a torque wrench. Right know im trying to fined a spindle at the junkyard if not i will try that. Do's any one else have any idea on what else would couse this.
99 vitara 4x4
99 vitara 4x4
Re: Front Bearing
Mr spanky, I believe the last person is corect when saying you should have used a torch wrench. <BR> But what I wanted to tell you is that you can save over 50% on front wheel bearings buy perchasing them for a 92-94 Ford escort. <BR> When I replaced mine Mazda gave me a price of $80each and I picked up the escort bearings for $30. <BR> Just an Idea.
- mrspanky79
Re: Front Bearing
Canadian Tire some were around $40 that also might be the problem. And when i put the nut on i tighten it as tight as i can and till the old marks (bent in part).
99 vitara 4x4
99 vitara 4x4
Re: Front Bearing
I worked at a Crappy Tire garage and had my wheel bearings done there by someone I could see that was decent, you can take it in for a free quote and do the work yourself if you wanted, they'll do alot to get your business.
- mrspanky79
Re: Front Bearing
i did the work my self but i bought both bearings from Canadian tire. I just would like to know why they keep going? I cant see how the torgue of the wheel nut will do it because there is a pin in there that holds the bearing in. If any one has any other ideas why or could explain it to me, thanks.
99 vitara 4x4
99 vitara 4x4
Re: Front Bearing
Mr Spanky, i am a mechanic, the only thing that sounds like is u have to much play to with the new barring(not having it tight to begin with)when u put a new wheele barring in that axil nut has to be very tight because any play u have in it will reduce the life of the barring. i would deffinatly look in a service manule for the torque spec. and use a torque wrench as sugusted befor.
- mrspanky79
Re: Front Bearing
thanks for the help im starting to see what you are saying im going to give it another try if I cant fined a different spindal this week. You are a mechanic how do you get the bearing out and it with out taking the spindal off of the car? I have been taking the spindal out and doing it on a bench press thats why i think we might of bent the spindal a little.
99 vitara 4x4
99 vitara 4x4
Re: Front Bearing
sorry i didnt get back sooner, that should be a press in barring (much like the ford escort) Snap-On makes a tool to do thoes type of barrings on the car, but it is vary expensive and not necessary unless u do them regularly. in your cace the best way to do it is to take the hub a--. off and use a hydrolis bench press. when u do make very shure to have the barring straghtbecause u can get the barring in the hub croked which can also kiss thoes barrings in a short amount of time. also make shure that the barring is seated all the way in the hub. i dont think that ive seen anyone bend a hub but anything is possible. most of the problems i see are with barring eg. not in all the way , in croked , axil nut loose, <BR>if u have any moor questions let me know glade to help.
- mrspanky79
Re: Front Bearing
Thanks for the help I think i know what the problem is know. By what you are saying I think we might of had the bearing slightly croked. Its very hard to do on a bench press.
99 vitara 4x4
99 vitara 4x4
