klze dyno
windofire
klze dyno
just wanted to share this, i was pretty happy with the graph
Black Mx3 GS
ZE swapped with kl36 ecu and Exedy oem clutch, Fidanza flywheel, 2.5" stainless exhaust, Ebay headers, 8mm sparkplug wires and Denso iridium sparkplugs, Rockspeed CAI, 17x8 wheels, 235/40 Goodyear eagle f1 as, Taroc japan sport discs and pads.
- WhiteFinish
Re: klze dyno
so that means your ze puts 186HP to the wheels??
- MrMazda92
Re: klze dyno
Those are pretty good numbers, you have a healthy engine!
windofire
Re: klze dyno
Yeah it does and it was actually dyno'ed twice and the first time it was on it showed 187 whpTfries-cc wrote:so that means your ze puts 186HP to the wheels??
i was suprised, i only hoped for 170ish. but i think its strange that peak hp is at 7100 rpm, isn't it supposed to be at 6500?MrMazda92 wrote:Those are pretty good numbers, you have a healthy engine!
Black Mx3 GS
Re: klze dyno
Do you have the kl31 cams and ZE long neck?
Very nice result indeed.
windofire
Re: klze dyno
No actually not its a curved neck with kl01 cams and kl31/36
Black Mx3 GS
- mitmaks
Re: klze dyno
Very good number, you lost only 14hp and ~15 tq, not bad at all!
- Josh
Re: klze dyno
The conversion to US HP and TQ is actually 183.7 WHP and 151 foot pounds of TQ.
I am surprised with the KL01 cams and those numbers. Great numbers! looks like the Fidanza is the way to go..
- kulluminati777
Re: klze dyno
those are great numbers. I want to get my car dynoed. I bet a MAF and MSD coil frees up at least 5+ on tq and hp. I would love to see 190hp and north of 155 on tq.
windofire
Re: klze dyno
i can't see how Theres a difference between European horsepower and US horsepower? could you please explain it?Josh wrote:The conversion to US HP and TQ is actually 183.7 WHP and 151 foot pounds of TQ.
but it's really great numbers and the fidanza really make a houge difference on ZE's
i've got a msd 6al waiting to go in with a blaster ss coil, outlaw spacers, interprep springs and cams will also come in near future and later on a VEMS ecukulluminati777 wrote:those are great numbers. I want to get my car dynoed. I bet a MAF and MSD coil frees up at least 5+ on tq and hp. I would love to see 190hp and north of 155 on tq.
just havent decided wich cams to go with yet, as i want the most power but still streetable. any inputs here? and anyone who knows what max lift is in a flat top ze? catcams makes some with 10mm lift and they are warning people that valves could hit the pistons, so that you may have to machine the pistons.
Black Mx3 GS
- Josh
Re: klze dyno
It is the difference between US standard unites of measure (inches, lbs or pounds etc.) and European units of measure. You guys are on the metric system. We use pounds you use stones.. kidding! But it is just a little different when it comes to the dyno numbers and how they are measured. If you search google you can find some handy converters.windofire wrote:i can't see how Theres a difference between European horsepower and US horsepower? could you please explain it?Josh wrote:The conversion to US HP and TQ is actually 183.7 WHP and 151 foot pounds of TQ.
Re: klze dyno
it says hk not hp. what is hk?
also torque maxed out at 3400 rpms?
1995 Eunos 30x KLZE
windofire
Re: klze dyno
Okay, i see. It makes good senseJosh wrote:It is the difference between US standard unites of measure (inches, lbs or pounds etc.) and European units of measure. You guys are on the metric system. We use pounds you use stones.. kidding! But it is just a little different when it comes to the dyno numbers and how they are measured. If you search google you can find some handy converters.windofire wrote:i can't see how Theres a difference between European horsepower and US horsepower? could you please explain it?Josh wrote:The conversion to US HP and TQ is actually 183.7 WHP and 151 foot pounds of TQ.
Hk is HesteKræfter in danish and its horsepower in EnglishRX8SE3P wrote:it says hk not hp. what is hk?
Torque maxing out at 3450 rpm seems right to me, if you're looking at the factory specs. But I'm wondering why my hp is at 7100 rpm and not 6500, I think it might be because of the fidanza.
Black Mx3 GS
Re: klze dyno
Seems all wrong to me actually.
What gear was the dyno using during testing?
KL01 cam curve neck is not a true KL31 engine. It's a Eunos 800 engine and at best had a 7 nipple disty and no egr which would mean it's a high compression jap import with KL01 cams.
If it has a 6 nipple disty and EGR, then it's a domestic engine with 170HP at the crank. How that can make 190 at the wheels, with KL01 cams. I don't know. But if it drives strong who cares?
EDIT: And to confirm, KL01 cams will max their power before 6000rpms. The KL31 cams make power at 6500rpms. The torque curve is also wrong, it should definitely make more torque and not take a dive like it does after 3400rpms. Do you have the AFR too? Love to see them with the KL31/36 stock ECU.
1995 Eunos 30x KLZE
