Window motor replacement
WhiteFinish
Post by WhiteFinish »
Hi Guys,
My passengers side window moves up reaaaalllllyyy slow.
I'm guessing one of these days it just won't move up anymore.
I found another windowmotor at a JY put i removed it with a bit of force.
Of course on my own car I want to replace it with a gentle touch ;)
Any tips on how to change them?
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
2fazed
Re: Window motor replacement
Post by 2fazed »
It depends on if it's manual or power windows.
Take the panel off, by unscrewing one screw on the outside of panel, and by handle.
Remove the plastic around the window motor track.
The window motor track will have 3 bolts holding it on the door. Manual will have an additional 3 bolts holding the door handle part.
Before taking it out, move the side window down so you can see both the screws that hold the side window on the track.
Unscrew the two screws, and take the side window out.
If powered, you'll also unplug the window motor from harness.
Then you can unbolt and take out the window motor regulator
Hope this helps.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
WhiteFinish
its a electrical window
So the trick is to lower the window.
Unscrew the bolts,
take out the glass.
Remove the motor
Put new motor in
Put glass back in ?
Worklog click
2fazed
Post by 2fazed »
WhiteFinish wrote:its a electrical window
Unscrew the bolts,
take out the glass.
Remove the motor
Put new motor in
Put glass back in ?
Yes, when you take the track out in the junkers, you cant move the window up and down, so you cant align the screws to the holes to stick a screwdriver in to unscrew the two that hold the side window. That's what makes it hard at the junkers, but easy at home when it's pluged in and powered.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
WhiteFinish
I've replaced the motor but it still doesn't function properly.
This is with the new motor
Down is no problem, but up won't work that well. Doesn't even reach the top.
Internals of the old motor. Is it possible to replace some things so it works again?
Worklog click
2fazed
Post by 2fazed »
Did you test the motor before install? Just hook the two wires up to the battery(power and ground). One way rolls the window up, there other way, rolls it down. If the motor works, could be the track. Maybe the cable is stuck.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
WhiteFinish
I was at the junkyard today and just grabbed another one.
This one seemed to work just fine when testing it there.
Worklog click
DeadMaker
Post by DeadMaker »
Did you had to take out the glass?
Black Mazda Mx3 Rs 1997 B6DE
mitmaks
Post by mitmaks »
lubricating track would help a bit.
WhiteFinish
Yes, there are 2 screws holding the glass to the motor device.
Unscrew them, push out the bumpers at the bottem of the glass and you can lift the window out.
Worklog click
WhiteFinish
What track do you mean mitmaks?
The rubber where the window sits in or something else?
I've replaced the motor again, with one that i tested at the JY, but still up is so much slower.
Worklog click
mitmaks
Post by mitmaks »
The one that glass rides. Also its possible that motor you got from junkyard is no better than the one you took off
WhiteFinish
The current motor worked fine with the glass in, at the junkyard.
Both up and down.
Now, in my car, it runs up (faster than my old one) but still not as fast as in the junkyard.
Worklog click
mitmaks
Post by mitmaks »
Check to see if anything is obstructing glass travel, like maybe glass run channel (9) is out of its place, etc.
WhiteFinish
I used some Teflon spray to get things smoother.
Still not superb but it will do.
Can't understand why at the JY it's so much faster than in my car :roll:
Worklog click
