Hi,
I'm doing a head gasket etc on a KLZE, can I use a standard MX-6 gasket set or is there a specific KLZE set that I need?
Thanks
KLZE Head Gasket
- marcdh
Re: KLZE Head Gasket
quite sure they're all the same as I mentioned in the mail i just sent you
Only real difference in gaskets is inlet manifold. This will do you nicely:
http://www.fordprobestore.co.uk/store/p ... ts_id=2025
I'm running that set with 215+ comp across the 6
View Worklog
![Image](http://marcharrington.co.uk/banner2013.png)
View Worklog
Thanks for the info on Gaskets.
Found some headers in the UK:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=022" onclick="window.open(this.href);return false;
are these the same as yours?
Thanks
Thanks
- marcdh
nice one, look almost identical, better if anything! The ports look alot tidier. If it was me I'd buy them, if "Each set is tested and dyno'd for maximum performance." then at least fitment will be spot on
Just remember your cat will have to be moved back about 8", but I'd imagine you'll get a custom catback to match anyway.
View Worklog
View Worklog
instead of catback just go to a shop that will put no cat in. just 2 1/4 back with a glasspack. That is... if you have no emissions.
Already got a catback at the moment, so will have to get something shortened somewhere.
Can I just use the Headers and keep my existing downpipe for now?
Until I have the money to get it shorteded.
