Coolant Leak..Cant find the source.
- navymx3
Re: Coolant Leak..Cant find the source.
Haha, yea I know, but thats for all the labor and everything, I know...friggin stupid...anyone wanna help me with this? is there a way to take off and replace the water pump without taking off the timing belt? like, keep the belt under high tension, but swapping out the pumps?
93 Mazda MX-3 GS V6 24V 5 Speed
oh i didnt know it was a 6 cyl lol. but yea try and find a friend oyu know or soemthing that is good with working on cars and take a day and fix it. by the end of it you will probly only end up spending 350- 400.
- navymx3
why 350-400? what could possibly cost that much? the water pump is only 75$, and a new serp. & timeing belt is only like 120$.
i was including your wheel bearings. so wit h120 and 75 and well my price i had 60 each for the bearings and than coolant aswell. litle over 300.
- navymx3
ahh mk. well do you know anyone around me that might be able to help? because im getting another car, thats more reliable, and ill use this car as a project car
So i can really supe it up, and get it nice ![Very Happy :D](./images/smilies/icon_biggrin.gif)
I've replaced the water pump in my previous MX3, V6 without taking the timing belt off. Also, I've replaced the timing belt and water pump on my current V6 with the engine still in the car. If you have any questions or anything as far as doing the work, I could help.
'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD ![Sad :(](./images/smilies/icon_sad.gif)
Buyer Feedback: viewtopic.php?f=37&t=62426" onclick="window.open(this.href);return false;
viewtopic.php?f=37&t=69003" onclick="window.open(this.href);return false;
"Amatuers practice until they can get it right; professionals practice until they can't get it wrong"
- navymx3
dude that would be aweslome if you could help. i dont work tomorrow so i could spend all day on the car
if you could provide very detailed instructions on what to do, that would be amazing ![Very Happy :D](./images/smilies/icon_biggrin.gif)
- mitmaks
Why are you not replacing timing belt. You're already in there and its recommended to do it at the same time. If your timing belt goes your engine is screwed.
- navymx3
because if i take off the timing belt, idk how to get the right timing...i cant afford a timing light, those are like 80$ or more. So if i can do this without taking off or effin up my timing, that would be best.
- mitmaks
that's why you need to get someone who know's what they're doing. Look at it this way...you're not going to tell your timing belt " I can't replace you cause I can't afford timing light" It snaps - it snaps, it won't ask you when you're comfortable replacing it. Find a do-it-at-home guy and i'm sure you can get it fixed for a fraction of a price.
I didn't read the whole thread so sorry if this has been suggested.
No timing light is necessary if the car is running good you only need to replace the timing belt and water pump.
Tip for replacing the timing belt: Assuming the existing timing belt is intact move the crank to top dead center (line up the camshaft gear marks with the marks on the cylinder head and timing back plate).
Use a paint pen to mark the timing belt at each camshaft and mark the crankshaft and make a matching mark on the timing belt.
Transfer these marks from the old to the new timing belt.
Now all you need to do is match the timing belt with the marks on the camshafts and crankshaft. Of course you need to be sure the marks align with matching marks on the cylinder head and timing back plate.
![Image](http://imageshack.us/a/img407/384/50r4.jpg)
I would def recommend doing the timing belt as well. Everyone doesn't mention this just because... I can speak from experience that it is an absolute b**** to rip everything down in order to access the water pump. Your hands WILL be sore and potentially bloody due to the lack of space.
You really only need a solid day to do it all.
-Take off all accessory belts, and tensioners.
-remove power steering pulley
-Support the engine from under it and remove the top drivers side engine mount.
-Remove timing cover (this will allow you to view the timing belt and water pump)
**you should be able to access the bolts to remove the water pump and re-install at this point if you do not wish to replace the timing belt; then just reassemble in reverse order**
For timing belt replacement:
-Move crank pulley to Top Dead Center (or TDC)
-Make sure timing marks are lined up on both front and rear cylinder heads
-Mark timing marks on cam gears and cylinder heads for re-alignment purposes
-Remove crank pulley
-Remove hydraulic tensioner.
-Remove timing belt.
-Compress hydraulic tensioner and insert a cotter pin to hold it in place
-Refer to FAQ page for installation order of the timing belt.
-Reinstall everything in reverse order and start her up!
This is a very basic guide but gives you an idea of what to do. There is a more detailed explanation if you use the search button or just read the FAQ's.
If your doing the pump do the belt. The work to replace the pump and your already there so to not replace the belt makes no sense. Have a look at the timeng belt adjuster as well. If it's leaking fluid (even a tiny amount) replace it. Most garages charge $550 - $600 in labour just to do the timing belt because of the time involved. Buy a NEW pump not rebuilt and good luck. ![Very Happy :D](./images/smilies/icon_biggrin.gif)
In the V6 FAQ...who would have thought...
http://www.mx-3.com/phpBB3/viewtopic.php?f=23&t=61958" onclick="window.open(this.href);return false;
Just had some time to help the guy out. I knew that the walkthrough was there since I've used it several times. Wasn't too much trouble to type out the basic steps in doing it. At least now when someone searches and sees this thread, they'll still be directed to the FAQ.wytbishop wrote:In the V6 FAQ...who would have thought...
Assuming they USE the search function that is
![Confused :?](./images/smilies/icon_confused.gif)
