I've never seen a stock 3 spoke steering wheel w/o cruise on it. The MX-3 I had in HS was a 4 spoke with airbag and the GS I have now has cruise controls on it. My question to someone that has done it before or knows, can I add the cruise controls from my steering wheel (which is severely deteriorated) onto a stock 3 spoke steering wheel that doesnt have it?
I've seen on the forums here where people modified the location of thier cruise control and such but I didnt really want to do that.
Just wondering if it would require wiring mods (clockspring wiring different) or cosmetic mods (having to remove/drill into/replace parts on the wheel)
I would like to have a stock wheel, so I'm not that interested in getting aftermarket/protege. Can anyone help answer this?
Stock 3 spoke Steering Wheel
MazdaMech
Own:
2012 Chevrolet Camaro LS
2006 Chevrolet Uplander LS
1999 Ford F-250 XLT LD
1992 Mazda MX-3 GS (Rescue from a poor handler) *In work*(Body, interior, (future - KL swap))
1987 Dodge Dakota LE
1983 Honda CX-650C +parts bike
Looking at:
TRYING TO FIND A MX-3 Daily! No Luck:-(
Looking at:
- Josh
Re: Stock 3 spoke Steering Wheel
Cruse control if mounted to the steering wheel will unscrew from the wheel.
- Evo_Spec
you can add cruise control to steering wheels that don't have it, you just have to make a cutout
MazdaMech
So how about the wiring? Will the controls go through the clockspring?
Own:
Looking at:
Looking at:
Tap into the wires and mount the CC switch in the steering bezel below the ignition switch. You need to glue it in there with like hot melt glue. I don't think there's any pics showing this being done as far as I know. I plan to do mine,,,some day as well.
MazdaMech
I didnt really want to change the location or get into tapping into wires. I just ordered a 94 Steering wheel in near mint condition without cruise control from a JY in Chicago. Want to take the controls off of mine, put on the new steering wheel and call it a day but honestly I've never changed a steering wheel so I wasn't sure how the wiring would work to get the cc connected.Daninski wrote:Tap into the wires and mount the CC switch in the steering bezel below the ignition switch. You need to glue it in there with like hot melt glue. I don't think there's any pics showing this being done as far as I know. I plan to do mine,,,some day as well.
Own:
Looking at:
Looking at:
If you don't have a puller have one person pull on the steering wheel and another hit the steering shaft (where you took the nut off) and the wheel should come free of the shaft. Careful not to damage/flare the shaft when you hit it. I usually use a brass drift or install a temporary nut to protect the threads.
RobMinhas
When I pulled off my steering wheel I reoved the bolt, then threaded it on enough so that it would stay on the smack the sides of the wheel with my palms, then the top, then wiggle as hard as I can then pull on that sucker with my feet on the dead pedal on the floor. The nut protects you from getting a face full of loose steering wheel too.
MazdaMech
Good suggestions, I will keep that in mind.
Own:
Looking at:
Looking at:
