ok so i have a few questions.
my struts blew on my gs and the drivers front spring broke.
ever since i changed the struts all around(not brand new but not blown) i have had a strange steering
when i hit a bump my steering wheel turns and my car jerks to one side. my question is if anyone knows what could cause this and how to fix it. i am also wondering if there are any mods for our suspention that will make it stronger inorder to take corners tighter. any help is welcome.
92 mx3 gs klze swap.
"nitrous is like a hot chick with an std you know you want to hit it but your afraid of the consequences"
more than likely your alignment is WAY off. Mine does that too but i know my alignment is off
and a full list of suspension mods;
SRD cross member
SRD rear tie bar
Mazdaspeed or corksport front strut bar
mazdaspeed or Corksport Rear strut bar
bpt323's Traction Bar on LCA´s
K-sport Coilovers
Whiteline or mazdaspeed Rear sway bar
mazdaspeed Front sway bar
ZX2 Tubular Trailing arms
Pierce motorsports tubular lateral links
C- Pillar bar
energy suspension poly urethane bushings to replace rubber ones all around
i have heard koni/ZX2 stuts with eibach springs or ground control sleeves are ok. Trust me just save up a few more bucks and get an ACTUAL coil over set up. Also any ebay un named stuff like strut bars and stuff your just wasting your hard earned cash so dont bother....
I'm running Ground Control sleeves(granted, mine aren't an off-the-shelf option), but honestly I like them quite a bit. If you go with a tender spring setup, you can have a variable spring rate without sacrificing much.
I love it, although figuring out exactly where I wanted the ride height was a PAIN. To each his own...
kulluminati777 wrote:more than likely your alignment is WAY off. Mine does that too but i know my alignment is off
SRD cross member
SRD rear tie bar
K-sport Coilovers
C- Pillar bar
Have you installed ZX2 Tubular Trailing arms?Do have them on now?Any pic?
Thanks..
I live an hour from Vancouver. Like if there was a store i would save money (as i am a collage student working part time and building a car) and then go buy them but as far as i m now there's no stores that sell performance parts for our cars
Yeah it's just hard to find people in my area haha. Really all i need to find is suspention stuff. Te rest i can mod to fit or just plain make. But thank every one for the list of things and a general way to acquire the parts
part numbers do not cross. It's similar, but likely different enough to cause a problem. Even if it does fit, it will have a different ratio and stuff.
2004 Honda RC51 --- Lost forever to some theavin' bastard My Worklog My feedback thread Never attribute to malice that which can be adequately explained by stupidity.
