Quick question for someone who may already know. Google has failed me once again.
Is the coil/coil pack built into the distributor or is it a separate part.?
Trying to fix an ongoing misfire.
Thanks
Coil built in to Dizzy or separate?
- marcdh
Re: Coil built in to Dizzy or separate?
built in and notorious for failing!
View Worklog
![Image](http://marcharrington.co.uk/banner2013.png)
View Worklog
Coil, Ignitor, 1 of the 2 Crank sensors and Cam Position sensor are all built into the Dizzy...
95+ no cam position sensor in the disty. Misfire could be spark plug, ignition wires but my suggestion is to go and have your injectors cleaned and checked.crazycanadian wrote:Coil, Ignitor, 1 of the 2 Crank sensors and Cam Position sensor are all built into the Dizzy...
