Is it possible to kill a computer with info?
- fowljesse
This is probably a dumb question, but here's what happened;
My MegaSquirt was acting up, running the car too lean, so I bought a laptop (because mine was also acting up.. computers hate me) to interface with MS. The laptop came with Ubuntu, so I downloaded a Linux based MS tuning program. When it came time for the program to ask the MS box what it was, MS lost power, and the car shut down. The MS never regained power. I opened it to find a loose wire, which I resoldered into place, but the MS never came back on. It has an LED that lets you know when it has power. I checked the ECU power wire that was spliced to run MS, and it had 11.7ish volts. The tuning program said, as MS died, that it was writing a lot of info, line after line kept popping up that said something about writing info. I'll try to get more info, if possible.
Re: Is it possible to kill a computer with info?
Your not asking if you killed your laptop, you're asking if you killed your Megasquirt?
When you're writing you MS, you're flashing an EEPROM chip. Typically a failed flash doesn't go well. You usually need special software to recovery it.
- fowljesse
Yes, I'm asking about the MS EEPROM. I have the info in the laptop, and will be sending the MS unit to a guy to diagnose and fix. The part I don't understand is the loss of power, but it may be coincidence that the wire came loose at the same time.. or maybe that is the actual problem.
- Inodoro Pereyra
A failed flash can freeze your processor, but it won't kill it. For what you say, that sounds a lot like a hardware problem to me, that may have gotten worse when you connected the laptop to it, not because of the data transfer, but maybe because of a power leak on either direction, or a bad connection, etc.
Getting the MS diagnosed is the right move, and so is moving to Ubuntu. Welcome to the club.
Diogenes of Sinope.
Diogenes of Sinope.
You would think for a few extra bucks Mega squirt would use a dual EEPROM. If one failed as may be the case here the other one would take over then reflash the fist chip. Ya losing power during a flash is bad news. Keep us informed as to the fix.
- fowljesse
Thanks, guys. I'm sending it out tonight.
Inodoro, I'm not smart enough to use Ubuntu, but I'm going to try. There is the Windows simulator, Wine, if I can't get used to the layout.
- Inodoro Pereyra
Neither am I.fowljesse wrote: Inodoro, I'm not smart enough to use Ubuntu, but I'm going to try. There is the Windows simulator, Wine, if I can't get used to the layout.
Go to http://ubuntuforums.org/index.php, and start asking questions.
For normal everyday use, Ubuntu is so much simpler than Windows that, after a few days, you will fall in love with it. What can get difficult sometimes is installing stuff. For that, Ubuntuforums is one of the most helpful forums I've ever been a member of.
Believe me: for the last 3 months or so, I've been sentenced to Windows 7 exclusively. I hate my life.
Diogenes of Sinope.
Diogenes of Sinope.
- fowljesse
Heheh. The laptop came from a place that recycles computers, and they are passionate nerds. It came with free tech support, as long as I keep Ubuntu on it. I have a good relationship with the place, so I can get help, when needed. Thanks for the link
- Inodoro Pereyra
Anytime.
Diogenes of Sinope.
Diogenes of Sinope.
That's a whole different story, MS isn't a computer, and was especting a PC question in the off-topis section.fowljesse wrote:Yes, I'm asking about the MS EEPROM.
I haven't touched anything but Windows since college, and I'm perfectly fine with that.Inodoro Pereyra wrote:Believe me: for the last 3 months or so, I've been sentenced to Windows 7 exclusively. I hate my life.
- Inodoro Pereyra
Because you don't know any better.Nd4SpdSe wrote: I haven't touched anything but Windows since college, and I'm perfectly fine with that.
Try Ubuntu. Once you get to know it, you'll understand my feelings on "Windoze"...
Diogenes of Sinope.
Diogenes of Sinope.
- fowljesse
My badNd4SpdSe wrote: That's a whole different story, MS isn't a computer, and was especting a PC question in the off-topis section.
mikeinaus
wine is in many cases a huge pain the in a-- to use. ubuntu however is a great o/s. ive been using it for years and would only ever use windows if and when i would decide to play a game.
hopefully the problem is a failed eprom, the board and other components would be salvageable relatively easily. did the board look like it had any burn marks or anything? and burnt metal smell? if there is no physical burn marks on the board its possible it can be fixed relatively easy if none of the main components are damaged...
I use windows, like it, and I fix them anyway, so need to be on the know on how to. My PC's always run a pirated version too, gotta know how to deal with those.
http://www.megamanual.com/ms2/V3trouble.htm
I found this...
does any of this information apply? Before checking anything else, make sure your stimulator has a fresh battery - many problems are traced to a low battery voltage, but only after a long, frustrating troubleshooting effort!
I have never used MS nor claim to know what's involved in it, but if any of it is helpful...
I found this...
