Rear Wheel Hub differences
MrMazda92
Post by MrMazda92 »
I'm replacing a damaged wheel hub on my '93, and the hub I purchased from RockAuto is slightly different than the OEM I removed. For those who don't know, it's a GS, so both hubs are for discs.
Here's a picture, if I need to label which is OEM and which is new, you need more help than I do :lol:
Evo_Spec
Re: Rear Wheel Hub differences
Post by Evo_Spec »
are you asking why they're different? or just noting that they are different?
cause the ribbed ring is for ABS in case you were asking, i'm sure if you found a non-ABS hub it wouldn't have it
MrMazda92
Post by MrMazda92 »
Thank you!
Wow, so it doesn't have ABS? :/ I was pretty sure it did, wow.
That hub should work anyways, shouldn't it? Measurements are the same, the gear just adds a bit of weight. :P
Evo_Spec
Post by Evo_Spec »
MrMazda92 wrote:Thank you!
i'm pretty sure it'll work fine
MrMazda92
Post by MrMazda92 »
Thank you for the quick response. :D Now just a new nut for the hub and I'll have 2 drivable MX-3s again.
RS_OBD'oh_2
Post by RS_OBD'oh_2 »
I know nothing about the hubs, but when I had an ABS shaft, the ring could be pulled off with little effort. Give it a couple shots with a dead blow hammer.
