door weatherstripping
has anyone bought these recently? i found some old threads saying mazda was charging under $50 each side and was wondering if current prices should be accurate to that? i called a local mazda dealer and they want $100 a side. i know stock is probably running low for them but wouldnt they charge less as less people are driving these cars?
Re: door weatherstripping
No, until they go into a discontinued status...mikeinaus wrote:i know stock is probably running low for them but wouldnt they charge less as less people are driving these cars?
If you have a part number use these guys (cheapest OEM mazda parts I have found): http://www.onlinemazdaparts.com/
What about a junkyard?
Most of the ones I've seen in junk yards are usually trashed. And id love to get back that nice "thud" sound u get with newer cars. I tried searching for that thread with all the weatherstripping part numbers yesterday but I couldn't find it. If I can comeup with the number ill give that site a look. Thanks moon.
found it! viewtopic.php?f=17&t=69775
does anyone know if i want the door seal or the door weather stripping? i want the big rubber part that attaches and surrounds the door.
- ethand
Hey mate, the last post on that link says:
When you say it goes all the way round, is that the little flappy bit that goes around the outside of the door, starting just below the window & going all the way round from there? Does anyone know if these seals are the same part number for JDM Presso's as with US MX3s?
So I take it that you're after the weather strip...onlytrueromeo wrote:Just to update, the door seal is a piece of molding or something, the door weatherstrip is the actual rubber piece that goes all the way around.
'92 JDM Eunos Presso - Zeke
they should be. i ordered a set from this guy http://www.ebay.com/itm/170677836261?ss ... 1497.l2649 they should come sometime this week. ill post when they arrive and let you know how install went.
it arrived today and it was totally worth it. my drivers door feels brand new. i can slam the door and its not even loud, just a nice thud. anyone know any tips for keeping the weatherstripping in good shape? other then not slamming the door that is. i think the main problem is the weatherstripping looses its rigidity over time and stops cushioning properly. my new set was quite a bit "puffier" then my old one.
- ethand
Awesome, so glad to hear it was worth it
I don't think its really possible with rubber - it's a perishable material, and it always deteriorates with age. I think extremes of heat/cold probably don't help it last any longer, but with a car, it's hardly possible to protect it from that...
- DeepBlueMX3
Is this for the right side only?Does haven't him the left side???mikeinaus wrote:they should be. i ordered a set from this guy http://www.ebay.com/itm/170677836261?ss ... 1497.l2649 they should come sometime this week. ill post when they arrive and let you know how install went.
yeah it was the drivers side. i didnt look too much for the passenger side as mine is still in fairly good shape, but the 5 mins i did spend i didnt turn up anything...
- DeepBlueMX3
- mazdaspeed23
i was going to by some new ones. and mazda wants $19.00 for the front window, $38 for the back. and $99 for each door
Own
1994 MX-3 GS swapped ZE
1994 MX-3 GS Swapped ZE (Gone)
1996 Dodge Dakota Sport v8 Magnum
2007 Ford Fusion SE
WORK LOG: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=81232
My MX-3 is nothing without me, and i am nothing without my MX-3
2007 Ford Fusion SE
- MrMazda92
- mazdaspeed23
im looking for some aswell, i called my local mazda dealer 2 weeks ago, they want $99 for each side. and $50 for the windshield
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
- kulluminati777
sounds about right for some reason these rubber pieces are expensive
