Intake+TB question.
- cWs306
Intake+TB question.
eh whatsup. i got a issue, if i got a millenia intake and all that jazz, but no throttle body. would i be able to use the throttle body that came on the ZE originally on the millenia intake? or do i need to find the specific throttle body for that intake??
Re: Intake+TB question.
Need a curved neck TB for the curved neck IM. JDM or USDM it doesn't matter. both the KL47 and KL68 are identical. I had both.
- cWs306
ahhhh gotcha! thank you sir! now onto the TB hunt. last part needed ![Very Happy :D](./images/smilies/icon_biggrin.gif)
- WhiteFinish
Like said above..
The IAC black thing doesn'[t work and interfear with your intake.
I dunno if this pertains to anything here but I took the IAC off the ze TB I had and used it on my K8's when it went bad just to get me by untill I could do my swap and the car ran fine so most of the parts are idinical no matter what spec. J or A it should work. I'm with NE4SPDSE on this one you should get it from the same type intake you have.
GS-ZE,fidanza fly/ 6 puck ceramic clutch,pacesetter headers/exhaust, AWR 88duro motormounts, P.R.M jetstream CAI,KYB GR-2 struts, KL31 ECU,JE-50VAF,110A Mellenia alt. S.S Corksport Clutch line.
You don't usually have a choice, a straight neck one doesn't fit, a K8 one does but well, that's really restrictive for the 2.5Mr.mx-3 wrote:I'm with ND4SPDSE on this one you should get it from the same type intake you have.
- cWs306
hey, question. so the KL02 throttle body wont work.? off a 626???
Does the 626 have a curved neck IM?
- Ryan
![Image](http://i295.photobucket.com/albums/mm121/Daninski/facepalm_picard_riker.jpg)
How about this.
![Image](http://i295.photobucket.com/albums/mm121/Daninski/facepalm.gif)
- RS_OBD'oh_2
Hahahaha.
- cWs306
sorry guys, im new to this swap. idunno exactly what makes these not work, wheres the IAC? is that the plug on the side of the TB? or is it on the bottom of it? if so the KL02 i found wouldnt work? cause it would hit the fuel/cooling lines? im so confused. heres a picture on the IM/TB...
![Image](http://i65.photobucket.com/albums/h236/smith-18/IMG-20110402-00042.jpg)
- cWs306
sooooo? should i just get my k8 TB bored to 65mm?
The IAC is the lower part of the TB, it's got the electrical connection to it
No, the K8 TB will not bore out to KL spec
This is a curved beck IM, you need the TB off of one of those, DE or ZE, they'r the same.
![Image](http://sphotos.ak.fbcdn.net/hphotos-ak-ash1/hs783.ash1/167307_193990743946861_100000078113418_714720_2098821_n.jpg)
- cWs306
yah i got a curved neck already.. i just need a TB. and i was told the K8 one will bore out to KL spec?? :S
