engine swap please help
mazdaman222
Post by mazdaman222 »
hi i am thinking about doing an engine swap in my 94 mx3. i want to take my 1.6(i4) 5 speed out and put a 3.0(v6) 5 speed from a ford tempo in it i need to know what all needs to be done and how hard it will be thanks.
Ryan
Re: engine swap please help
Post by Ryan »
I'm going to go out on a limb and say you've never attempted a motor swap before.
Nothing will fit at all. Nothing will plug in. Nothing will match up. You'll need custom axles. You'll need to weld in new engine mounts. You'll need a full custom wiring harness.
Look through the FAQ, worklogs, and http://www.mx-3.com/phpBB3/search.php" onclick="window.open(this.href);return false;
You're looking for a 1.8L BP (T) swap.
mazdaman222
no i havent done an engine swap before. but all i hear about is everyone wants a klze in there mx3 so i decided i will try a 3.0l just to be different lol. and i kind of figured none of the wireing would work i was just looking for anny bit of info annyone had
Dark_Rider2k3
Post by Dark_Rider2k3 »
The problem is that no-one has tried it as far as I've known. There are only a handful of swaps done in our cars. The most common being the BP, BP-T, KLDE, and KLZE.
Engine swaps, also, are NOT as fun as they may seem. The end result is awesome, but if you have to go the route of custom stuff, then your in for a lot of $$$$s spent.
mazdaman222
ya nothing in life is cheap
Ryan
Post by Ryan »
If you have money, go for it. The list I posted before is just the tip of the iceberg.
Who knows how those sensors readout, you might need to swap the dash/gauge harness in so your gauges work right.
you'll need to know your way around electrical schematics. You'll need wiring diagrams from both cars, you'll need to know how to use a soldering iron. you'll need to know how to weld, and you'll for sure need an engine hoist.
The custom axles will be expensive, $300+
You'll need custom exhaust work.
You should do some physical measurements to make sure it fits in the bay, or you're screwed from day 1.
tip of the iceberg....
mazdaman222
ya thanks for the tips
Dark_Rider2k3
Yeah, also make sure that, if your a mechanical speedometer, that you can custom make the mechanical speedometer work, or if you need to swap in an electronic speedometer and custom wire it in.. or something..
mazdaman222
ok thanks.
im not starting it yet cuz i need to find someone to help do it but when/if i get it done i will post some on it
mazdaman222
hey if i find a gs will it be ezer to do this swap?
Ryan
Post by Ryan »
no it won't be ezer. It won't be ezer if you find an M1 tank. It'd be ezer if you found a car that shared a platform or motor option with that engine.
Ryan wrote:no it won't be ezer. It won't be ezer if you find an M1 tank. It'd be ezer if you found a car that shared a platform or motor option with that engine.
:lol:
Indeed. I can guarantee that the Tempo 3.0L project would never happen, losta of work, lots of money, for sadly poor gains: only 155hp and 160tq, less than a KLDE, which would be helluvalot easier to swap, still alot of work and money to put a KL V6 into a 4cyl Mx3, but a more feasible option compared to the Vulcan 3.0, and those motors are old, going to be hard to find one in good shape and low milleage.
On an odd note, they did have the 3.0 in the 1st Gen Ford Probe. It's not at all the same platform, but physically it should fit.
mazdaman222
i can get like 4 3.0l engines right now they are the same as the 3.0l rangers and the areostar
Oh ya, forgot about that actually. Was thinking cars from the era, but totally forgot about the Ford trucks (and the Mazda B3000). Still, wouldn't suggest it...
mazdaman222
ya i will TRY to find someone that can help me do it. or find a ze
