mx3 5 speed need help
FastFlaMx3
Post by FastFlaMx3 »
my mx3 is acting weird i have to have a 3-4 grand rev when let out on clutch pedle or it will jerk ans act like it is in a higher gear and the car it surging it revs from 800-1g really weird pls help any info would help
http://www.cardomain.com/ride/3882183" onclick="window.open(this.href);return false;
h3xt0r
Re: mx3 5 speed need help
Post by h3xt0r »
Are you saying that its surging like its not getting enough power or it feels more like its just "grabbing" after a little while? If its the grab I had a similar problem in my car a while back and it ended up being the clutch. The clutch is probably worn out and slips then eventually gets traction and grabs hard.
-H3xT0r
kateCapshaw wrote:The moment somebody says to me, "This is very risky," is the moment it becomes attractive to me.
Ryan
Post by Ryan »
bouncing idle is also caused by vac leaks.
FastFlaMx3
i got new vac lines and it helped ty i got the master cyl and slave cly now just need a few day off work to get it done i hope this helps the tranny
Return to “Transmissions”
