flywheel
Re: flywheel
KL flywheel will work, but it's heavier. Mx6 owners actually put in an Mx3 flywheel for better performance.
So yes it works, but actually a downgrade
Re: flywheel
I'm running a MX3 stock fly. With an XTD (Lame) clutch. I have the stock mx3 tranny i'm going to swap to the aluminum flywheel my question is should I run the mx6 fly or mx3 aluminum fly. I'll get faster rev off the mx3 fly im sure its lighter than the mx6... I was talking about aluminum flywheels sorry I didn't make that more clear. Thanks
- EggyRollz
Re: flywheel
Go with whichever one is lighter then.DiaMagus wrote:I'm running a MX3 stock fly. With an XTD (Lame) clutch. I have the stock mx3 tranny i'm going to swap to the aluminum flywheel my question is should I run the mx6 fly or mx3 aluminum fly. I'll get faster rev off the mx3 fly im sure its lighter than the mx6... I was talking about aluminum flywheels sorry I didn't make that more clear. Thanks
94 Tahoe Sport SS - 454 =)
93 3KGT VR4 - K&N Filter.Proxes 4 Tires. Drilled/Slotted Rotors.
97 Tahoe - Grill gaurd.Oversized Tires.Custom liners.Bored & matched pistons.E-cam.Leather.Remote start.TCC upgrade.+Sunshell.10K tow package.Knifed TB.Flowtech Huggers.Straight pipes.Hypertech chip.B&M Trans Controller, Front diff & T-case plates.
Feedback-viewtopic.php?f=37&t=74259
For Sale-viewtopic.php?f=2&t=74832
Re: flywheel
I'm not sure why this is a question really... if you have an oem flywheel and a lightweight flywheel, why would you question using the lighter one if you already have it? I could see if you were thinking about buying one.
Go with the aluminum, unless it's some off-brand that you would question the integrity of...
'94 MX3 GS (black)-- 2.5L DE w/ straight neck IM, SSAC Headers, KYB-GR2's, Intrax Springs, CM Stage I clutch, OBX STS, filled front & rear mounts, CAI- SOLD
Re: flywheel
I have a stock mx3 flywheel. What I am "asking" is will the kl flywheel fit the k8 bellhousing. I guess is the bottom line -
cheers
Re: flywheel
\mazdags94 wrote:DiaMagus wrote:I'm running a MX3 stock fly. With an XTD (Lame) clutch. I have the stock mx3 tranny i'm going to swap to the aluminum flywheel my question is should I run the mx6 fly or mx3 aluminum fly. I'll get faster rev off the mx3 fly im sure its lighter than the mx6... I was talking about aluminum flywheels sorry I didn't make that more clear. Thanks
The company I'm going through only supply's an mx6 flywheel. I don't have an aluminum flywheel yet- So I'm going to buy one. what I'm saying is- Do you think there will be a big difference between an mx6 aluminum flywheel and an mx3 flywheel since they don't provide the mx-3 flywheel. I hope you can understand this better . :p
Re: flywheel
well what company are you using and how light is their flywheel? I'm not sure why they would have different flywheels... the only aluminum flywheels (9lb.) I would use are fidanza and aasco...
Re: flywheel
+1Mooneggs wrote:well what company are you using and how light is their flywheel? I'm not sure why they would have different flywheels... the only aluminum flywheels (9lb.) I would use are fidanza and aasco...
- PATDIESEL
Re: flywheel
I didn't think there were 9lb flywheels made anymore. Aasco is like 12 iirc, but anyway.
Yes, the MX-6 or Probe flywheel will fit a MX-3 trans bellhousing. There is no difference in the trans case since it is still a G series trans
My Alum flywheel is Aasco for a Mx-6/Probe and works very well.
Re: flywheel
no, the fidanza and aasco are both 9 lbs. (I've weighed them myself). here is the thread I started when I was debating what flywheel to go with: http://www.mx-3.com/phpBB3/viewtopic.php?f=15&t=66748" onclick="window.open(this.href);return false;PATDIESEL wrote:I didn't think there were 9lb flywheels made anymore. Aasco is like 12 iirc, but anyway.
I am curently using the fidanza in the DD and the Aasco in the RC. I think they both feel the same (they should) and I have not had a single issue with either of them. The surfaces are replaceable and I think they are well worth the investment.
