coolant sensor
ramsen25
coolant sensor
Post by ramsen25 »
hey guys i got a 1994 ze with a chipped ecu and im pulling a coolant temperature sensor code im goin to buy the sensor but do i get the sensor for a 1.8 or a 2.5
solo_ryder
Re: coolant sensor
Post by solo_ryder »
ramsen25 wrote:hey guys i got a 1994 ze with a chipped ecu and im pulling a coolant temperature sensor code im goin to buy the sensor but do i get the sensor for a 1.8 or a 2.5
Shouldnt matter. But you have a 2.5L so get the 2.5L one. Go to the wreckers.
_-Night-Shade-_
Re: coolant sensor
Post by _-Night-Shade-_ »
They are the same.
ramsen25
Re: coolant sensor
Post by ramsen25 »
Kk kool thank you
davmac
Re: coolant sensor
Post by davmac »
Beware. 3 temp senders. 2 (both 2 wire) can throw a diag code. Green 2 wire is used to control idle, black or gray 2 wire is used to control radiator fan. Both of these are monitored by the ECU diagnostics. The 3rd temp sender is 1 wire and connects to the instrument cluster. All 3 temp senders are mounted near the coolant fill neck at the front of the engine.
Re: coolant sensor
Ok not to argue or anything but I'm of the believe you buy in accordance to your ECU. If your running a 1.8 ECU then buy 1.8 parts. Does this make any sense? Kinda like you have to use the disty appropriate to your model year,,,sort of. In saying this I'm not talking about exhaust or intake manifold gaskets or stuff like that, like D-uh. :D
_-Night-Shade-_
Re: coolant sensor
No, it depends on what it is. In the case of coolant sensors (or any sensors on the K engines for that matter) they are all the same.
Re: coolant sensor
_-Night-Shade-_ wrote:No, it depends on what it is. In the case of coolant sensors (or any sensors on the K engines for that matter) they are all the same.
Indeed
Re: coolant sensor
Indeed
That's all well and good and I don't think we needed to beat that one to death. I was talking about any year/ECU specific part. Can't remember and I'm too lazy to look but what about the knock sensors?
Re: coolant sensor
Indeed
