Doors from a 93 fit on a 94?
Maliceday
Wanting to switch to elecric windows and such, but instead of adding motor and harness and all of that, I am just going to swap the doors if they will fit. Anyone know if they will fit right? I can work out all the wireing if they do.
Nitrous is like a hot chick with a STD. You know you wanna hit it, but you are afraid of the consequences...
mikeinaus
Re: Doors from a 93 fit on a 94?
yeah you shouldnt have a problem. just make sure you dont brake the connector for the wiring harness near the hinges. theres 2 clips on the sides inside the door fame you need to pinch then it will pull out.
- Savin
From what other members have said in the past, the cars are already wired for electric windows. So if you get the doors and the wiring harnesses that go with the doors, there should be connectors inside the car you can plug in to.
'93 MX-3 GS - SOLD!
'93 MX-3 GS SE - Parts car!
'94 MX-3 GS - Scrapped
'94 MX-3 RS - Scrapped
'96 Sunfire SE - Scrapped
'03 Sunfire SE - Deathtrap
'95 Cavalier Base - Scrapped
'89 Mustang GT - SOLD!
'93 MX-3 GS - SOLD!
mikeinaus
the wiring harness would be those plugs
Took me like 2mins to remove the electric window assemblies. I'd use whatever doors are in the best shape rust wise. Remember, the electric window switch wiring changes from 93-94.
- DeepBlueMX3
Yeap there's a thread for thatDaninski wrote:Took me like 2mins to remove the electric window assemblies. I'd use whatever doors are in the best shape rust wise. Remember, the electric window switch wiring changes from 93-94.
http://www.mx-3.com/phpBB3/viewtopic.php?f=44&t=66265" onclick="window.open(this.href);return false;
Maliceday
Sounds great, and thank you. I noticed that there was a fuse slot for the pwr windows and figured that there was either a wire bracket that just needed connected, or that I would have to make one, but with going through all the wire diagrams that wouldn't be to difficult to fit them in if that were to be the case. I'm probably heading back down to the yard sometime between Thursday - Saturday and check the shape of the doors and such. All I would really have to worry about then would be paint.
I'm working on picking up a cheaper air compressor and a sprayer and figured I could give it a shot and see how it works. The doors will give me a pretty decent 'test plate' to work on till I can get it down pat I figure, then, on to painting the full car.
