Fog Lights Problem
Eunos 30X/Presso/Autozam AZ-3 Discussions
eric881104
Fog Lights Problem
Post by eric881104 »
Can anyone teach me to how to take the foglights out?
and Is it hard to change the sunroof motor by yourself?
PATDIESEL
Re: Fog Lights Problem
Post by PATDIESEL »
The stock fogs, you need to take bumper off first from what I can tell, but I do not have stock fogs atm. to double check that.
The motor looks like you need to take the whole things out to get to. Check the manual on the home page for Mx-3.com to see what you are getting into.
Are you trying to remove the entire foglight housing or just changing the bulb?
If the entire housing, yes, removing the entire bumper is the best way to go since it attaches to the internal support.
If just the bulb you can remove the cover of the bulb with the 2 screws on the front of it (either phillips or allen screws).
eric881104
I wanna change the fog light bulbs, but have no idea where to start.
and does anyone know how to take the whole headlights out?
I have been trying to take it off, and I unscrewed three screws two on the top one is on the side, then i still couldnt take it out.
eric881104 wrote:I wanna change the fog light bulbs, but have no idea where to start.
did you see my post?! :confused2: if you need pics try this: http://www.uk-mx3.com/forum/viewtopic.php?t=1813" onclick="window.open(this.href);return false;
it doesn't get much simpler man... :shrug:
eric881104
Thanks I finally got it out. :D
Would you mind to tell me how to get the headlights out as well please?
Lori Carlyle
Post by Lori Carlyle »
2 bolts connected to the top of the headlight
1 bolt toward the rad
1 bolt behind the headlight (only way I got at it was to take the bumper off)
Owner of the UK MX3 site.
Yes taking off the front bumper really is the best to not damage anything even though it's more effort...
Lori Carlyle
First time I tried I removed the side lights and could see the bolts! didn't take the height into consideration and promptly snapped both horns off the car. :(
Easy way to get front bumper off is
Pop hood
Release the splash guards from the bumper (Front of each front wheel)
Remove the bolt at the top edges of the front bumper (where it meets the wings - near splash guard)
Remove the side lights
Disconnect the electrical wires from foggies
Remove the 4 Bolts that mount the front S-beam to the main frame and pull.
IIRC I think that's it.
Return to “Eunos 30X/Presso/Autozam AZ-3”
