I am getting error codes 25 (Solenoid valve - pressure regulator control) and 69 (Water thermosensor - Fan).
here is my other post that shows the manual: http://www.mx-3.com/phpBB3/viewtopic.php?f=15&t=73233" onclick="window.open(this.href);return false;
I am not sure what solenoid I am looking for and where it is located. also on error 69 it sounds to me like the sensor might be ok? but just registering high water temps? or does it mean my sensor is bad, also from what I understand there is more than one water temp sensor on the car... where would this one be located?
Thank you so much for your help
