97-01 Escorts are easy to find at the wrecking yard.
Ended up cutting mine off with a chunk of Escort control arm
To remove the old bushing either use a press or you can drill a million holes in it and pry it out. I cleaned mine out with a sanding drum on a drill and painted them.
I used a inexpensive press to push my bushings in, but you can use a piece of wood and a big freakin' hammer too.
There you go! Inexpensive Poly bushing upgrade for your MX-3. A wheel alignment would be a good idea after this. My front sub frame was out, but you could leave yours in and just take your lower control arms off to up-grade them. (restoring my car).
