disassembling the transmission
mazdapr
Post by mazdapr »
i will be installing a phantom grip on a 93 mx3 gs transmission but i cant find the procedure how to take the trans apart. if anybodu has it let me know.
umcamara
Re: disassembling the transmission
Post by umcamara »
Here's a complete tear-down and rebuild, but you'll need to register (free).
Click Here
'98 BMW 328is M-Tech
Feedback Thread
I really really really would not recommend installing that... :| you're going to end up spending more money in the long run you might as well get the LSD from MFactory and do it right the first time...
The link I was going to give is the same as umcamara - also check the shop manual...
mazdapr
Post by mazdapr »
Mooneggs wrote:I really really really would not recommend installing that... :| you're going to end up spending more money in the long run you might as well get the LSD from MFactory and do it right the first time...
why?? i keep reading good stuff and bad stuff about this product but when i see a negative feedback about it i dont see no explanation no reasons. just its bad stuff dont used it.
Return to “Transmissions”
