disassembling the transmission
i will be installing a phantom grip on a 93 mx3 gs transmission but i cant find the procedure how to take the trans apart. if anybodu has it let me know.
Re: disassembling the transmission
I really really really would not recommend installing that...
you're going to end up spending more money in the long run you might as well get the LSD from MFactory and do it right the first time...
The link I was going to give is the same as umcamara - also check the shop manual...
Mooneggs wrote:I really really really would not recommend installing that...you're going to end up spending more money in the long run you might as well get the LSD from MFactory and do it right the first time...
why?? i keep reading good stuff and bad stuff about this product but when i see a negative feedback about it i dont see no explanation no reasons. just its bad stuff dont used it.
