18" tire size help
PURPLEFLEA
18" tire size help
Post by PURPLEFLEA »
Anyone know what the max tire size or best tire size is to use on 18"s with a stock suspension?I am planning on lowering it about 1 1/2" later down the road.THANKS :?
yence
Re: 18" tire size help
Post by yence »
Most common size for 18's on the mx-3 is 215/35's.
1995 noble green MX-3 RS (sold)
1994 clear white MX-3 GS (r.i.p.)
1987 white RX-7 FC
1993 mighty grey MX-3 GS
93vtecklr
Post by 93vtecklr »
I'd stick with a 215/40..........................17
haha just buggin, i second the 35 series, maybe a 205 profile though?
1993 Blaze Red SE, 17" blackie's, b+m sts, 45 deg 3" exh pipe/intake tube, K8ZE, aftmkt probe headers, magnaflow hi-cat, all 2.5" piping, magnaflow muffler.
1976 Datsun 620 p/u, full airride, Firestone 2600`s, 16ga fuel cell, Optima yellow top, AZ compressor, custom tubular frame with 9in step notch, 18" 100 spokes
1955 Willys Overland 4x4 P/U, '78 LT1 350 cu.in, fully restored.
solo_ryder
Post by solo_ryder »
215 35.
If they made a 205 35 it would be even smaller of a sidewall. I have never seen a 205 35 in real life. Almost all 18" rims are at least 7" wide neways so 215 is a good fit
PURPLEFLEA
Thanks guys,Will the 215/35 fit with any type of suspension drop? :?
PURPLEFLEA
Btw,Thanks Yence for the tip on the eyelids.You were right about the evilyeti site. :crying:
solo_ryder
Yea that will fit fine, shouldn't rub. Just make sure you get some camber bolts to even out the camber.
Make sure the rim has an acceptable offset as well, 40-45mm will be fine
PURPLEFLEA
Got it,Thanks Solo !!
Pedro_mx3
Post by Pedro_mx3 »
i have 18s with 215/35/18 tyres on an its extrememly close at the back, so be careful with a suspension drop u might want to doctor the arch just a tiny bit to clear it.
Edited: Typo's
I'm not worried about the bullet with my name on, Im worried about the one that says 'To Whom it may Concern'....
Make a Donation, Keep Mx3.com Alive!!
1991 V6 K8 -- My baby, i miss her... On her way to car heaven... <3
PURPLEFLEA
Thanks,I'm actually rethinking the 18"s,I may go with 17"s.Way cheaper to shoe,and alot more aimed towards the tuner look.
