Do I have any other options besides witchunterperformance.com? $18 an injector...
OR does anybody have a set of ZE fuel rails they want to sell cheap (that actually work)?
AHA I forgot about that... so maybe if I get a red bottle of Heet and just ride it out mabye my injectors are bad after allstereoking15 wrote:also, it probably didnt help that you put alcohol in your tank to pass emissions more alcohol equal bad, alcohol does not have the same btu's as gasoline, so it literally dilutes the fuel if you use too much,
