getting keyless entry
Car Stereo/Alarm Discussions
CrimsonReign1
Post by CrimsonReign1 »
im looking to get keyless but all i want is keyless, no alarm or autostart. maybe an alarm if its not much more money but i really dont care about it.
i came across this and i was wondering if anyone else has tried it and if its legit. i have power locks fyi
http://www.emiata.com/KEPL/MazdaMX-3.htm" onclick="window.open(this.href);return false;
93 SE, black
Ryan
Re: getting keyless entry
Post by Ryan »
You can get universal kits that work fine. There is a writeup floating around on here, try using the search feature.
http://www.mx-3.com/phpBB3/search.php" onclick="window.open(this.href);return false;
Wait, what are you saying? You have power locks, but no keyless entry? Thats freaking useless(power locks), all you have to do is stretch out your right arm and flick the switch...
CrimsonReign1
alright, but why would i want to extend my arm when i can just press a button?? besides, my passengers never lift up the door handle when they close the door so it dosent lock
93 SE, black
Mad Cow
Post by Mad Cow »
They sell the same stuff on ebay but a good deal cheaper, although the instructions are probably universal it's not exactly hard to wire it up. I've been thinking of getting a door actuators and a trunk actuator because I have a pretty nice keyless entry system sitting in my basement just begging to be installed, and they key lock on the trunk is broken for some reason, so I have to unlock the door and pull the handle to pop the trunk.
KLZE-ed '94 RS/'92 GS hybrid -- It's complicated :lol: -- Now somebody's winter beater
1999 Audi A4 2.8Q -- New ride
Dark_Rider2k3
Post by Dark_Rider2k3 »
The keyless entry is easy.
1. remove the door panels.
2. You should have 2 actuator "guns", and 2 "rods" that connect to the guns. Connect the rods to the guns, and then connect the rod to the other rod in the door (the rod that controls the lock/unlock)
3. Find a good spot that is not in the way of things to mount the actuator guns (obviously 1 on each side). Make sure after mounting that the rod can slide freely left and right, and it locks and unlocks the door.
4. Follow the wiring diagram that comes with the kit, and wire it up.
5. Test it out and enjoy
g-mac
Post by g-mac »
Princess auto has a cheap kit. Haven't tried it but it looks like it would be ok.
http://www.princessauto.com/truck-trail ... ord=remote" onclick="window.open(this.href);return false;
Here is the write-up noted above: http://www.mx-3.com/phpBB3/viewtopic.ph ... less+entry" onclick="window.open(this.href);return false;
my feedback: viewtopic.php?f=37&t=56291" onclick="window.open(this.href);return false;
Mad Cow
Post by Mad Cow »
g-mac wrote:Princess auto has a cheap kit. Haven't tried it but it looks like it would be ok.
The ones they sell are the exact same as the ebay one, and they also have single actuators, which will be alot cheaper if you already have an alarm to put in. http://www.princessauto.com/truck-trail ... power+lock $5 each is a steal.
If your getting keyless entry, I would suggest to get an alarm with that, it just makes sense and adds that layer of security.
If you have a GS, you don't need to add one on the passenger side, and really, you don't even need to wire it up since the passenger side has one, and it does that the drivers side does.
umcamara
Post by umcamara »
You can easily get a 1-way remote starter that does keyless entry for $60, and buy an actuator for $5. That Princess deal is no steal.
'98 BMW 328is M-Tech
Feedback Thread
nitefire bought one. PM him
Return to “Car Stereo/Alarm”
