Hey guys,
I'm doing a CAI from scratch. Can anyone tell me the ZE's intake diameter? What about the KL02 VAF's diameter?
I've searched and searched but can't find a definitive answer. Hopefully this topic will be easy to find in search.
KLZE intake inlet external diameter
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
- marcdh
Re: KLZE intake inlet external diameter
VAF out 86mm
VAF in 78mm
Kl31/47 TB 68mm
That's for the je50s, not sure if they're the same. That's what I had in some notes, hope they're right!
VAF in 78mm
Kl31/47 TB 68mm
View Worklog
View Worklog
Figures. Nothing simple.marcdh wrote:VAF out 86mm
VAF in 78mm
Kl31/47 TB 68mm
Ok, I'll go measure them to make sure before I order; I was hoping they were just standard sizes like 70mm.
- Gord
68mm ~= 2 5/8"
Ok well for what it's worth, I ordered:
1x 2.75" aluminum pipe with 45 degree bend (12" long)
1x 2.75" silicone coupler + clamps
1x 3.25" -> 2.75" reducer + clamps
1x 3" cone filter
So I'll connect the aluminum pipe to the throttle body inlet with a 2.75" coupler, then use the reducer to connect the other end to the VAF. Then, I'll attach the air filter to the VAF inlet.
I'll post pics once I've got it all together.
I know it's not a CAI, but at least it'll get me off of the leaky stock intake crap.
1x 3" cone filter
- Gord
hi there i know this isn't really part of this but not sure where to put it has anyone seen this intake for the klze it is a custom one tried to email but there box was full .. what do you think here is the site http://www.spitzeperformance.com/Production.html
What is a BILLION.....???
A billion is a difficult number to comprehend:
A billion seconds ago it was 1959, and I was a teenager!
A billion minutes ago B.C. became A.D.
A billion hours ago our ancestors were apes.
A billion days ago no-one walked on the earth on two feet.
