Drag race suspension setup
A forum for Drag Strip/Track Racing Discussions. (NO Street Racing or Kill Stories, they WILL be deleted.)
cjthor
Post by cjthor »
This year I am going to be working more on susupension/weight transfer. Please post up what you are using for springs/struts! Is it working for you? Thinking of making a change?
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
mazdax3speed
Re: Drag race suspension setup
Post by mazdax3speed »
I wanna see how this thread fills out, I'm very interested in other peoples setups
does anybody have a list of spring rates for the more common mx-3 srings?
Orange 95' BPT GT28r, MSII on the way
marcdh
Post by marcdh »
Not exactly on topic, but I'll be putting in some rubber spring spacers to try and reduce squatting the rear. I've no idea what rates my lowering springs are, came with the car, about -45mm, but my front end lifts up alot and my rear goes way down. Next big purchase for me will be Ksport coilovers I think.
View Worklog
mazdax3speed
I don't know about Ksport but D2 started making drag coilovers with stiffer spring rates, i assume Ksport makes them too, they seem to be about $200-300us more than their regular coilovers
Robx1r
Post by Robx1r »
mazdax3speed wrote:I don't know about Ksport but D2 started making drag coilovers with stiffer spring rates, i assume Ksport makes them too, they seem to be about $200-300us more than their regular coilovers
ksport and d2 are the same crowd!! :D when i'm draggin i just harden the bount on the rear and soften on the front
kiwimx3
Post by kiwimx3 »
mines top secret, but a 1.8 60ft is pretty good.
Id get a 1.6 60 ft if I was to run a wheelie bar out the back
as I could transfer more weight to the front.
harder springs in the a-- makes for a hairy top end at over 180kmph
limit straps on the front stop a lot of upward travel and are a very cheap
addition
mazdax3speed
anybody else? doesn't matter if its nothing special, i want to know what works/what doesn't
also maybe post your 60' times as well
cjthor
Post by cjthor »
kiwimx3 wrote:mines top secret, but a 1.8 60ft is pretty good.
Thanks for not helping. I think most guys with basic suspensions have seen 1.8 60' times.. I know if have with blown struts and ground control coilovers.
Jarid Perry
hppwdn
Post by hppwdn »
I used the adjustable spring blocks (the ones with bolts and little metal plates) in the rear of mine. They're in the same section as the rubber spring blocks usually. It massively decreased my travel in the rear. You can see how far it jacked up the back in this pic
http://www.iceyrecords.com/drew/mx3/Gol ... aptrix.jpg" onclick="window.open(this.href);return false;
I agree with the above comment on high speed stability though. At high speeds (130+) with very little travel in the rear slowing down is not for the faint of heart.
Currently I have a set of ksports on order (perpetual back order). I ordered them mainly to fit a wider/taller tire combo, but I like the options for drag racing as well.
fowljesse
Post by fowljesse »
Cjthor has no fear.
cjthor
Post by cjthor »
fowljesse wrote:Cjthor has no fear.
I've died once....been threre done that.
Jarid Perry
fowljesse
Post by fowljesse »
I bet it would help to replace all your bushings with 90A Poly ones, and de-activate your rear wheel steering.
cjthor
Post by cjthor »
fowljesse wrote:I bet it would help to replace all your bushings with 90A Poly ones, and de-activate your rear wheel steering.
Hopefully the car is going in the shop tonight to finish up pulling the dash..more weight reduction!!
Jarid Perry
fowljesse
Post by fowljesse »
Lemme know if you want some help.
I'm good with the sawzall, and tire iron, and BFH.
cjthor
Post by cjthor »
fowljesse wrote:Lemme know if you want some help.
youre more than welcome to attend! 7pm my place. LOL
Jarid Perry
Return to “Drag Strip/Track Racing”
