KL31 ecu
KL31 ecu
hey guys since some people having this obd2 klze problem with the 1996 mx3 if i got the actual klze ecu kl31 would it be better to put in my car most likely gonna have to change the harness but overall performance would it be at max
- JM1EC-V6
Re: KL31 ecu
1996 v6 = no way it will run the KL31 ECU despite you convert your OBD2 harness with a OBD1 one (1992-95)
'94 Mx-3 GS-R SE, KL-ZE Interprep. (From '96 PGT KL)
1110Kg
-Interprep KL31 Spec.
ported heads, Polished combustion chamber,3 angle vlv job,10.3:1 C.R.,0.020'' O.S.,KL31 cam,-0.007'' heads,Long neck IM,KL31 TB, Hotshot headers,2.25'' exhaust,Magnaflow cat
1110Kg
Re: KL31 ecu
Just run the stock ECU and use MSD window switches (RPM activated switches) for VRIS. The OBDII MX3s use the same injectors as the KL's, which is the main reason people swapped or chipped OBDI MX3's.
But why wouldn't a KL31 ECU work with an OBDI harness? It has the same pinout and everything.
KLZE-ed '94 RS/'92 GS hybrid -- It's complicated -- Now somebody's winter beater
1999 Audi A4 2.8Q -- New ride
- solo_ryder
Re: KL31 ecu
the KL36/31 works fine on OBDI cars. Its just that even with that ecu the vris points are still off.
Like Pascal said, the best option is to run your OBDII ecu with some window switches or a VR-tuner (if you can find one). The main point for you is to get the car running, and running fairly well before you start worrying about making massive power. Just get the damn motor in and get it running and then go from there.
Re: KL31 ecu
Really? That's news to me?Mad Cow wrote:The OBDII MX3s use the same injectors as the KL's
Re: KL31 ecu
Whoops, disregard that. I was looking up injectors on ebay a while ago and saw that MX3 injectors fit the MX6 and 626, but I didn't check the year, they fit the first generation cars with their 2.2L I4.Nd4SpdSe wrote:Really? That's news to me?Mad Cow wrote:The OBDII MX3s use the same injectors as the KL's
In that case, you'll likely have to swap in an OBDI harness and get a probinator ECU chip.
Re: KL31 ecu
Oh...well, K8, KJ and KJ injectors are swappable too, FYI.Mad Cow wrote:Whoops, disregard that. I was looking up injectors on ebay a while ago and saw that MX3 injectors fit the MX6 and 626, but I didn't check the year, they fit the first generation cars with their 2.2L I4.
Re: KL31 ecu
I'm pretty sure there is a such thing as a OBDII KLZE ECU. KL62 or something like that.
You can always try an OBDII MX6 ECU with KL02 VAF. That would go way better than a K8 ECU.
Or you can swap wiring loom and use KL31/36.
1995 Eunos 30x KLZE
Re: KL31 ecu
I give up. I've given you all the info you need. Your just complicating things for yourself. Go ahead and swap the Harness. Go through all that work, chip a ECU whatever then when you have problems up the hoop and your trying to figure out the multitude of issues you have I'll be cruising around with my ZE just purring away enjoying life glad I didn't do something as unnesassary as harness swaping. My final word.
Re: KL31 ecu
I believe it's been mentioned that they supposibely use a different pin-out.RX8SE3P wrote:I'm pretty sure there is a such thing as a OBDII KLZE ECU. KL62 or something like that.
Talk to Daninski, he's got plenty of info inregards to the OBDII swap.
