Drivers Door Sensor
Drivers Door Sensor
When i open the drivers door the interior light doesnt come on. I cant find the sensor so test it. Where is the senor located?
- Ryan
Re: Drivers Door Sensor
Open the door. Stand facing your car. Bottom right. Its a little button.
thanks.
the piece had been broken off and is sitting in side the frame. im guessing i wont be able to fix that one. i cant even see the wire
Basic switch. Almost every car is the same. Mine are not working as well.
Same issue: http://www.mx-3.com/phpBB3/viewtopic.php?f=38&t=67114" onclick="window.open(this.href);return false;
- Ryan
I don'tknow for sure, but I think if you take the rear panel that has the pass side back seat arm rest and the sill off, you can get to it.
- Newfie_dan
just remove the retaining screw you can get it wiggled out of there. Its a faulty ground that causes it to not work. Its just a simple ground witch pin out=ground pin in=no ground. Rust in this area can cause it to not ground properly to.
