Lots of good things in here.. and bear with me, I don't have pictures for all of it. The stuff I feel is most important to see, I took pictures for. PRICES ARE SHIPPED TO USA WHERE NOTED. So here it goes..
3) Port Matched KLDE heads. Intake ports blended and matched to KLZE ports. Exhaust ports gasket matched to stock gasket and log manifold. Great upgrade and doesn't have the valve retainer problem like the KLZE heads do. I do have and will include all the matching cam caps.
Never overheated. I made over 400 whp on these exact heads before they were ported.
$160 + shipping
7) Megasquirt n spark V2.2 PCB. harness, wiring diagram, base map included. I can also include my 550cc tune. Worked perfect. Includes both GM sensors.
$300 shipped
12) OBD1 remanufactured 92 93 KL V6 disty. Works perfect. Clean. Won't work on 94+
$80 shipped
13)Small FMIC. Can get the dimensions if you are interested. You can get the idea from the picture $75 shipped
14) VRIS solenids. $30 shipped
17) Stock KL 5 spd trans.
$280 shipped
18) "24V DOHC" KLZE Mazda Valve cover.
$30 shipped
19) Polished, shaved label front valve cover. Looks nice. Can be seen in the millenia intake manifold engine bay picture link.
$40 shipped
20) KLDE crankshaft. Good journals. Not scored or otherwise, never had oil problems.
$85 shipped
21) Tapped KL oil pan. Fitting welded onto front side of pan.
$40 shipped
22) Resonated test pipe. 2.5", with 02 bung welded in (don't worry, it has a plug included as well) Fits MX3 perfect in stock location with stock flanges
$35 + ship
I think that's it. If I can remember more I will add them as they come.
