FS- 400 hp MX3 part out-
I can't believe the time has come for me to do this... but I've got yet another semester of school to pay for, two other cars, two bikes, and one of which is a big project, so this stuff has to go.
Lots of good things in here.. and bear with me, I don't have pictures for all of it. The stuff I feel is most important to see, I took pictures for. PRICES ARE SHIPPED TO USA WHERE NOTED. So here it goes..
3) Port Matched KLDE heads. Intake ports blended and matched to KLZE ports. Exhaust ports gasket matched to stock gasket and log manifold. Great upgrade and doesn't have the valve retainer problem like the KLZE heads do. I do have and will include all the matching cam caps.
Never overheated. I made over 400 whp on these exact heads before they were ported.
$160 + shipping
7) Megasquirt n spark V2.2 PCB. harness, wiring diagram, base map included. I can also include my 550cc tune. Worked perfect. Includes both GM sensors.
$300 shipped
KL engine gasket kit. Bearings included. $110 shipped
12) OBD1 remanufactured 92 93 KL V6 disty. Works perfect. Clean. Won't work on 94+
$80 shipped
13)Small FMIC. Can get the dimensions if you are interested. You can get the idea from the picture $75 shipped
14) VRIS solenids. $30 shipped
17) Stock KL 5 spd trans.
$280 shipped
18) "24V DOHC" KLZE Mazda Valve cover.
$30 shipped
19) Polished, shaved label front valve cover. Looks nice. Can be seen in the millenia intake manifold engine bay picture link.
$40 shipped
20) KLDE crankshaft. Good journals. Not scored or otherwise, never had oil problems.
$85 shipped
21) Tapped KL oil pan. Fitting welded onto front side of pan.
$40 shipped
22) Resonated test pipe. 2.5", with 02 bung welded in (don't worry, it has a plug included as well) Fits MX3 perfect in stock location with stock flanges
$35 + ship
I think that's it. If I can remember more I will add them as they come.
$160 + shipping
$300 shipped
$80 shipped
$280 shipped
$30 shipped
$40 shipped
$85 shipped
$40 shipped
$35 + ship
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
Re: FS- 400 hp MX3 part out-
Sorry to see you are not completing your build!
92 MX-3 GS 2.5 KLZE
14.385 @ 98.21
14.385 @ 98.21
- johnmx3ze
f--- it sucks that i dont have money right now i'd buy your fuel pump and the Megasquirt n spark V3.0 PCB...
f---...
f---...
- johnmx3ze
my car is a 94 would the Megasquirt n spark V3.0 PCB be ok?
Yes, You will have to wire it in or Rebel2k4 here can make you a plug n play harness for $100. If you have to ask it MS will work with your car you have alot of learning to do....Still.
- johnmx3ze
yea well its because i saw his add on ebay and it said that it will not fit 94+ so thats why i asked...mx3boyze wrote:Yes, You will have to wire it in or Rebel2k4 here can make you a plug n play harness for $100. If you have to ask it MS will work with your car you have alot of learning to do....Still.
It will indeed fit the 92-94 MX3 V6, and maybe even 95-96, however not the 95+ MX6/Probe. They have a different disty setup.
Thats what I used it in, was my 94 MX3. It is actually running the car as we speak
But anyhow, I am selling the performance parts, not the car. Not so sure I can let this thing go yet. 64k miles and almost 5 years later and I still love this car
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
- onlytrueromeo
Do the VRIS solenoids also include the plastic valve thingy for the curve neck? My Curve neck did not come with it so the VRIS doesnt work right.
- hppwdn
If you start to part out any interior parts or body parts let me know. I have a short list of things I'm looking for.
- tehbrookzorz
Dibs on the fuel injector set-up. I will pm you shortly with some questions.
Cody
got any more pics on the 210 shipped turbo?
HIGHLY INTERESTED
HIGHLY INTERESTED
-hec
Sure thing man... what is your email?
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
hgallegos915@msn.com" onclick="window.open(this.href);return false;
-hec
I also have one of those turbo's he has for $210 shipped. I guess I will lower my price to 210 shipped.
- fowljesse
I want the MegaSquirt. Bare with my noob questions... Will it work with my DE with a ZE disty with ext. coil, and GM HEI module?
