Whats causing my turbos to fail?(FIXED)
hgallegos915
Any ideas? Im uing restrictors, got a HUGE drain line.
I even used real garret and it smoked...
what am I doing wrong?
tons of bad ebay turbos, one bad nissan and one bad garret.. my luck cant get any worse...
[EDIT]
Oks.. i got the EBAY turbo to stop smoking..
well i just kinked the oil line a bit.. I noticed my buddy had it like that.
and another fellow turbo mx3 who uses ebay turbos. He is using a motorcycle oil line.
So im going to rig up some sort of regulator so i can regulate the oil psi at 20 which is what garret recommends on my kind of bearings.
there ya go!
we can use ebay turbos.. as long as we regulate the oil supply.
Cold psi was 75!!!! with the restrictor..
[EDIT]
there ya go!
Last edited by hgallegos915 on October 3rd, 2008, 5:36 pm, edited 1 time in total.
-hec
- solo_ryder
Re: Whats causing my turbos to fail?
You proly have a kink in your oil line
- ElectricEnergy
Re: Whats causing my turbos to fail?(FIXED)
75psi? holy crap. do the ebay turbos just have a really restrictive path for the oil or something? It sounds to me like one of the biggest faults for the cheap turbo is that they smoke a lot. If reducing the oil pressure keeps it from blowing through the seals, maybe I'll play around with one.
KL-ZE Swap - OBX SS Headers - 2.5" Exhaust - Falken Azenis Tires - H&R Springs - ZX-2 Struts - CAI - Front & Rear Tower Bar - AWR Motor Mounts - 100hp wet shot (yet to be tested)
Yea they arent too bad as long as you can maintain a happy level for oil pressure.ElectricEnergy wrote:75psi? holy crap. do the ebay turbos just have a really restrictive path for the oil or something? It sounds to me like one of the biggest faults for the cheap turbo is that they smoke a lot. If reducing the oil pressure keeps it from blowing through the seals, maybe I'll play around with one.
Though they tend to not perform as well as their legitimate counter parts. they use less quality materials and they use an ancient style of balancing the turbo, were talking 70's-80's style baby
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
hgallegos915
man i fixed the problem and the car HAULS!
NO SMOKE!
I love it!
NO SMOKE!
I love it!
-hec
- solo_ryder
What was the issue Hec?hgallegos915 wrote:man i fixed the problem and the car HAULS!
NO SMOKE!
I love it!
Was I right?
hgallegos915
I just needed to control the oil pressure.
I kinked the line.
It smokes when the line becomes unkinked LOL
I need to develop or get some sort of valve to control the pressure the right way.
Reading around, we only need around 20 - 30 psi for those turbo. Actually garrets
I kinked the line.
-hec
turbulence23
please let us know how you restrict the oil flow to the turbo as that might be a good reason for me to try out a kit sometimes if it really is that problem only
arent there ready made restrictors available to put between the oilline and the turbo to prevent these high pressures
and how did you measure the pressure at the oilline?
2.5L KLZE engine, CF hood, Postert frontbumper, kmax skirts, custom diffusor..
MY RIDE:
http://www.mazdamx-3.nl/members/member_show.php?id=102
MY RIDE:
Use an oil feed restrictor.
.065 should be adequate.
93' Rs-t BPT - Sold
93' Rs-t BPT - Sold
hgallegos915
I was and it was not working for me.. maybe something is wrong with my engine?
no smoke still..
day 3 of driving it.
Ive even driven long drives and its good.
no smoke still..
-hec
- johnmx3ze
hey hgallegos915 i saw your video on youtube,,, NICE!!! and you said that when you kink the oil feed line the ebay turbo works???does it really...
hgallegos915
yeah.. believe it or not LOL it does LOL
i was like WOAH..
one day it was smoking alot.. the line had become unkinked.
o I squished it a bit with some lock jaws and it work well.
i was like WOAH..
-hec
- johnmx3ze
oh ok lol nice so i guess i'll buy and ebay kit and whats your email?
hgallegos915
hgallegos915@msn.com" onclick="window.open(this.href);return false;
why? are you going to paypal me some free money for finding out? lol
-hec
Red Rocket
you could get a needle valve for and hydraulic line with compression fit ends for the size of oile line your running, then you could have pretty accurate and reliable pressure.
[*url=http:cardomain.com/ride/2632839]My Cardomain Page[/url*]
