PARKING BRAKE LIGHTS-- going crazy
with the 5spd tranny.. ok here's whats been happening, Key on Engine Off or Running the Parking Brake Light would come ON when both door are close. it will remain ON and goes OFF when you open the door or step on the clutch paddle. Its driving me CoCO ... any insight on this would be very helpful .
93' blue mx-3, klze curve neck, kl36ecu, all the upgrade possible/out turbo.
Re: PARKING BRAKE LIGHTS-- going crazy
Check brake fluid level first -
If brake fluid is full - then you will have to get into the wiring and figure out if there are any short circuits...
![Image](http://img517.imageshack.us/img517/5927/fliegetn0ss7.gif)
brake fluid level switch is working good fluid level is full, the E brake cable switch is testing out good, and the door switch are also fine. on wire diagram this should be a very simple setup, but there is that module underneath the driver seat. will investigate on that. i was hoping this would be a common problem, maybe it could just be my bad luck. if it comes down to it, this could be a long night and a few cases of beer tracing down individual wire.. i will keep an update on this, and any comment or advice is good..
