Well i took a look on ebay for a turbo but i don't know which one is good.
Is this one a good choice:
http://cgi.ebay.ca/93-97-Ford-Probe-MX- ... dZViewItem" onclick="window.open(this.href);return false;
MX-3 KL-ZE Which turbo will fit in?
- solo_ryder
Re: MX-3 KL-ZE Which turbo will fit in?
Well, the trubo and the wastegate are not very good, they are hit and miss (mostly miss).nathan259 wrote:Well i took a look on ebay for a turbo but i don't know which one is good.
The best option here is to get a set of hot pipes and then get a decent turbo (t3/t4 garrett) with a good tial 58mm wastegate. Here is a link to the hot pipes:
http://cgi.ebay.ca/Ford-Probe-2-5L-KLZE ... dZViewItem
You need to modify the crossmember to make these fit as they hang to low for the mx3's. Do a search, there is alot of info on boosting a v6.
the turbo is like 99% a miss LOL
the bov hit and miss, the wastegate , i opened it up and used real tial internals.
-hec
- se7en
Lol, and I am the 1% that says they work fine if you treat them right, and rub them right.....
not that I don't abuse mine everyday but...
So, clearly, what should I buy and where?
Post links if you can... Don't need to be the most powerful one, i only want quality...
http://cgi.ebay.ca/Ford-Probe-2-5L-KLZE ... dZViewItemThe best option here is to get a set of hot pipes and then get a decent turbo (t3/t4 garrett) with a good tial 58mm wastegate. Here is a link to the hot pipes
- Flinch
lol 58mm wast gate, over shooting it by a bit there big a guy a 38 mm will do you just fine till about 400hp buddy dont spwnd the extra money. if you want to drag the car get a decent zised t3 if not and you want to autocross it get a smaller t3 for quick spool up in the corners.
-KL31 stock internals with curved neck intake manifold and KL36 ecu
-Turbo running 7.5psi
-FMI 3"x12"x32" all alluminum and welded, have a 7.5 PSI spring she just creeps on cold nights
-ACT 6puck sprung/96 probe tranny
-Short shifter
-HEI and MSD 6al (makes a big difference when you spend the 65$ ont he right spark plugs)
-KYB GR-2 struts with H & R springs
-Megan racing seats
-Personal 280mm stearing wheel
-Familia rear strut tower bar
-Short shifter
-Megan racing seats
But with that...I don't have an intercooler...where can i find it? And which one?
If you had to ask which turbo will fit "in" your MX-3, You still have alot of research to do. Check out the book "Maximum Boost" by Corky Bell.
