WTB: B6 DOHC Cylinder Head
like the title says i need a b6 dohc cylinder head asap. only need the head with valvetrain and cams. i have the rest. thanks
best way to contact me is through aim: nate2k540
thanks
thanks
- mx-3_4evr
Re: WTB: B6 DOHC Cylinder Head
I got a B6 DOHC head but no cams.... where are you located? I will sell it to you for cheap, just let me know
i'm in iowa. yesss, been looking for one of these high and low. how much you want shipped to 51543 and any idea on mileage or condition? pics? does it need milled?mx-3_4evr wrote:I got a B6 DOHC head but no cams.... where are you located? I will sell it to you for cheap, just let me know
- mx-3_4evr
I will take pictures for you later on today... It had 140K miles on it, so it needs to be cleaned and milled like any other used head. I was going to use it on my build but I changed on what engine I'm going to use. I also have a perfect condition crankshaft that has been cleaned, checked, and grind down for .030 main bearings / .010 rod bearings. B6 block, B6 DOHC intake manifold, TB, injectors, etc... Let me know if you need more parts, I have plenty here!
alright cool thanks. i should have most everything i need except for the head itself. i was just replacing a (possible) blown headgasket but just want to be prepared in case the shop finds that its cracked. thanks!
- mx-3_4evr
here are the pics
Will do $80 shipped. I will bring it to the machine shop to have them check it before I sell it to you. Will also include the 3 studs missing from the exhaust side + all the bolts and cams caps also. Let me know what you think.
-Thanks!
-Thanks!
pics don't work?
- mx-3_4evr
F*! I will post them again, hold on
does it come with the HLA's and do you happen to have an exhaust manifold?
- mx-3_4evr
sure I will throw in the HLA's, sorry not exhaust manifold...
ok, was there anything wrong with the motor when you removed it. from reading your prifle on car domain you said the motor was smoking?
if so then i already have a head (i think) causing that ha. i don't want to have to replace valve seals if i don't have to.
- mx-3_4evr
yeah it did smoked, I really don't know what it was ether. My best guess was the piston rings but it could of been the valve seals... Remember it's a used head, it's not going to be perfect. Full re-build is recommended
