WTB: B6 DOHC Cylinder Head
Looking for an Item you'd like to buy? Post here.
This section is NOT for selling.
nate2k5
Post by nate2k5 »
like the title says i need a b6 dohc cylinder head asap. only need the head with valvetrain and cams. i have the rest. thanks
best way to contact me is through aim: nate2k540
thanks
mx-3_4evr
Re: WTB: B6 DOHC Cylinder Head
Post by mx-3_4evr »
I got a B6 DOHC head but no cams.... where are you located? I will sell it to you for cheap, just let me know :D
nate2k5
Post by nate2k5 »
mx-3_4evr wrote:I got a B6 DOHC head but no cams.... where are you located? I will sell it to you for cheap, just let me know :D
i'm in iowa. yesss, been looking for one of these high and low. how much you want shipped to 51543 and any idea on mileage or condition? pics? does it need milled?
mx-3_4evr
Post by mx-3_4evr »
I will take pictures for you later on today... It had 140K miles on it, so it needs to be cleaned and milled like any other used head. I was going to use it on my build but I changed on what engine I'm going to use. I also have a perfect condition crankshaft that has been cleaned, checked, and grind down for .030 main bearings / .010 rod bearings. B6 block, B6 DOHC intake manifold, TB, injectors, etc... Let me know if you need more parts, I have plenty here! :lol:
nate2k5
Post by nate2k5 »
alright cool thanks. i should have most everything i need except for the head itself. i was just replacing a (possible) blown headgasket but just want to be prepared in case the shop finds that its cracked. thanks!
mx-3_4evr
Post by mx-3_4evr »
here are the pics :D
Will do $80 shipped. I will bring it to the machine shop to have them check it before I sell it to you. Will also include the 3 studs missing from the exhaust side + all the bolts and cams caps also. Let me know what you think.
-Thanks!
nate2k5
Post by nate2k5 »
pics don't work?
mx-3_4evr
Post by mx-3_4evr »
F*! I will post them again, hold on :D
nate2k5
Post by nate2k5 »
does it come with the HLA's and do you happen to have an exhaust manifold?
mx-3_4evr
Post by mx-3_4evr »
sure I will throw in the HLA's, sorry not exhaust manifold...
nate2k5
Post by nate2k5 »
ok, was there anything wrong with the motor when you removed it. from reading your prifle on car domain you said the motor was smoking?
if so then i already have a head (i think) causing that ha. i don't want to have to replace valve seals if i don't have to.
mx-3_4evr
Post by mx-3_4evr »
yeah it did smoked, I really don't know what it was ether. My best guess was the piston rings but it could of been the valve seals... Remember it's a used head, it's not going to be perfect. Full re-build is recommended :D
Return to “MX-3 Related Want to Buy Forum”
